Latest version of Hatari ST/Falcon emulator for Morphos
    Lastic
    Posts: 13 from 2021/6/7
    beworld wrote:
    yeah... You are certainly right...
    Just wanted to check if you had any further progress ?
    Thanks for your time invested
  • »21.09.24 - 14:38
    Lastic
    I am probably the only person who really would like to use Hatari on MorphOS.
    ACE and Hatari are the 2 main reasons I'm keeping my iBooks around.
    Anybody able to assist in building 2.5.0 to a working state ?
  • »17.03.25 - 16:15
    Lastic
    First will need to upgrade to Morphos 3.19, install the newer SDL libraries and then test.
  • »18.03.25 - 06:13
    beworld
    Posts: 652 from 2010/2/10
    yes :-) need last beta tinygl :-)
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »18.03.25 - 07:14
    Lastic
    So after discovering that my Registered MorphOS iBook G4 14" CD/DVD no longer functions and having to use my iBook G4 12" as a work-around , I finally was able to upgrade to Morphos 3.19, install the newer SDL and try-out Hatari 2.5.0.
    Hatari 2.5.0 functions, I can now choose floppy images in any directory and they work.
    Only thing not working is the GEMDOS harddisk emulation but I have a suspicion that is related to the underlying Hatari code not knowing how to deal with an MorpOS filesystem.
    GEMDOS drive basically mimicks a harddrive_to_directory_on_your host_mapping, well that is the very non technical explanation.
    Still need to test the ACSI Harddisk emulation.
  • »22.03.25 - 09:41
