MorphOS runs on QEmu
    matt3
    Posts: 774 from 2004/2/10
    Is QEmu a viable solution compared to a real Powerbook or Powermac? Can you drive multiple monitors?
  • »25.02.23 - 22:37
    Posts: 3275 from 2003/3/5
    No and no.
  • »25.02.23 - 23:55
    Will it have a No April/AprilI/AprilII setting?
  • »03.05.25 - 19:20
    Posts: 12498 from 2003/5/22
    > Maybe I'll at last register MorphOS for my old Peg1,
    > and then replicate it with Qemu.
    Can registered MorphOS 3.19 be run on QEMU without time limit? This wasn't possible with 3.18 and before at least.
  • »04.05.25 - 12:36
    QEMU's AmigaOne emulation doesn't emulate the Articia S bugs, so probably not.
  • »04.05.25 - 12:38
    Addendum:
    Also implied by OSnews:
    "All you need is Kyvos [...] and a copy of [...] MorphOS. [...] A copy of MorphOS costs about €79, and can be bought from inside MorphOS after installation. Note that you can also use MorphOS without a license, but it will slow down its performance after about 30 minutes until you reboot."
  • »01.09.25 - 09:31
    Georg
    Posts: 129 from 2004/4/7
    Note that an emulator does not necessarily have to tell the thing that it emulates the truth about how fast time passes ...
  • »01.09.25 - 15:21
    sergius
    Posts: 47 from 2005/12/6
    Does someone here tried Kyvos ?
    https://ko-fi.com/s/6476fdadd2
    I'm trying it without good luck.
    When I try to create a new VM for Morphos, I get an error from HollywoodPlayer.
    [ Edited by sergius 07.12.2025 - 15:32 ]
  • »07.12.25 - 14:31
