MorphOS runs on QEmu
    Intuition
    Posts: 1110 from 2013/5/24
    Spectre660 wrote:
    Anyone know if KVM on an X1000 would work ?.
    Not yet.
  • »17.07.18 - 17:12
    Intuition
    koszer wrote:
    Intuition wrote:
    Call me stupid but which figure am I supposed to be looking at to compare it to this?
    http://sintonen.fi/pics/lame_benchmark.png
    I guess it's encoding time in seconds. Efika does the job in 2 minutes and 20 seconds (140 s). PowerMac G5 2,7 GHz encodes this wav in 8 seconds. Now for the screenshot you posted the situation is interesting. The real time differs from estimated by a very high margin (and on a real machine - it's never this way, as the "real" equals to "estimated" ultimately). I guess something isn't right with the timer under emulation. I'd probably go for the ETA number and a stopwatch just to be sure.
    It took around a minute roughly.
    Will run it again to make sure and on much faster hardware too.
  • »17.07.18 - 17:14
    jacadcaps wrote:
    Intuition wrote:
    virtgpu support will eventually come and it'll pass through a Radeon card that will appear on the pci bus to MorphOS and use it's native drivers.
    That won't help with a buggy and slow CPU emulation though.
    Yet another reason not to emulate the cpu, Jacek.
    Power 9...not X64, that would take care of that issue. ;-)
    Repetitive, I know, and very few have those systems, but it would run legacy PPC code.
  • »17.07.18 - 20:59
    Posts: 12074 from 2003/5/22
    >>> I'd be willing to bet that this could be done better on Power9.
    >> QEMU-KVM doesn't work as yet so no running this on any PPC
    >> or Power9 without emulating it same as on x64 for now.
    > [...] it would run legacy PPC code.
    Would? Does? Will? I'm confused :-)
  • »17.07.18 - 22:02
    Again, not just yet. But soon KVM should be a possible option.
    Interesting that I'd never considered the X1000, but that could serve as well.
    What about the final G5s? I know the 970FX doesn't have a hypervisor (apparently disabled from the Power 4 subset it was taken from), but QEMU-KVM already appears to be working on these.
    BTW - The low performance of PPC emulation on X64 doesn't surprise my, Mark told me it was borderline months ago and he wasn't sure if PPC emulation would make it into NG. Apparently primarily due to an issue related to available resources.
    The question becomes what do we want to do with emulation, because it won't be supported outside MorphOS.
    Then again, Nik's results are pretty remarkable, so maybe this is something the community can do on its own.
  • »18.07.18 - 00:46
    Posts: 80 from 2017/9/10
    KVM will work for sure for Morphos vmachine and better than emulated one because the emulated cpu use emulated altivec instruction thing that for my experience is not good working because make in idle the vcpu.
    for use the morphos in kvm do just sudo modprobe kvm and add --enable-kvm on Qemu command line.
    I dint have time to test myself because i dont have a monitor attached on my g5 quad, this days summer make this machine unusable because add more celsious in the home that is warm in the summer period (two days ago was 42° external and 30° in the home)
    PS: X1000 and G5,G4 are kvm compatible for Mac99 vhw
  • »18.07.18 - 07:53
    pampers
    Posts: 1061 from 2009/2/26
    Can anyone post some quick tutorial how to run this on MacOS for lamers like me? ;)
    MorphOS 3.x
  • »20.07.18 - 13:30
    what version of macos do you have?
    in case you are speaking about an old leopard or tiger (PPC) qemu dont build any more on it.
    in case you are speaking about new x86_64 Osx . you need to install homebrew and start build there from source qemu (note you need to be little skilled about).
  • »20.07.18 - 15:43
    Intuition
    git clone https://github.com/qemu/qemu
    cd qemu
    ./configure
    make -j8
    make install
    qemu-img create -f qcow2 morphos.img 120G
    # Boot from CD with HDD attached
    qemu-system-ppc -machine mac99,via=pmu -m 1536 -vga none -device sm501 -hda morphos.img -boot d -prom-env 'boot-device=cd:,mac_ppc32boot.img' -bios openbios-qemu.elf -serial stdio -net nic,model=rtl8139 -net user -cdrom morphos-3.11.iso
    Install MorphOS using IWizard.
    #Boot from HDD
    qemu-system-ppc -machine mac99,via=pmu -m 1536 -vga none -device sm501 -hda morphos.img -boot c -prom-env 'boot-device=hd:,boot.img' -bios openbios-qemu.elf -serial stdio -net nic,model=rtl8139 -net user
  • »20.07.18 - 20:32
    pampers
    Cheers guys, will try that later on. Where do I get open bios files?
    MorphOS 3.x
  • »21.07.18 - 09:39
    waldiamiga
    Posts: 90 from 2007/7/25
    Here OpenBIOS.elf
    Good site - Amiga like OSes on QEMU
    MorphOS.pl
    Core i7 Notebook|WinUAE 3.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 6.x.x
  • »21.07.18 - 10:03
    Intuition
    Heads up for everyone, I seem to be getting a lot of corruption when using a qcow2 image.
    Stuff copies and works fine but then after a reboot is corrupted.
    Gonna try using a raw image instead.
    edit:
    Same with a raw image. Hmmmm.
    [ Edited by Intuition 21.07.2018 - 13:26 ]
  • »21.07.18 - 12:46
    use max 10GB img and use raw format
  • »21.07.18 - 14:47
    Intuition
    Even a 10GB image gives random corruption.
  • »21.07.18 - 22:51
    strange i dont have this issues
  • »22.07.18 - 14:23
    Spectre660
    Posts: 275 from 2015/6/30
    Floating point performance at 18% ? .
    eh hem .
    At least with regards tpo AmigaOS 4.1 Tabor looks to be a better option at this point.
    [ Edited by Spectre660 23.07.2018 - 10:10 ]
  • »23.07.18 - 14:10
  • ASiegel
    Posts: 1370 from 2003/2/15
    eh hem .
    No offence but "qemu is even slower at FPU operations" is nothing to brag about.
  • »23.07.18 - 15:05
    Just for info ...
    the qemu devs are working for have better fpu operations in qemu.
    One option can be have the fpu operations in another cpu thread and not in the same thread where all the machine is emulated.
    PS: The integer operations on my machine is more faster then a G4 1.67 Ghz it mean much more faster then a tabor one and i have only 31 threads more available for have 31 AmigaOs more at same time.
    [ Edited by tlosmx 23.07.2018 - 15:35 ]
  • »23.07.18 - 15:32
    Spectre660
    Any practical application that you can think of for 31 AmigaOs's at a time ?
    Apart from maybe software development/debugging ?
    Also what happens with floating point performance under KVM ?
    Look at it from the point of view that AmigaOS 4.1 and MorphOS 3.xx still perform well on real Sam460's and X5000's as well as MorphOS on the other supported hardware .
    Also Improvements in video performance are done (But not yet released) for AmigaOS 4.1 for the Sam460 and X5000 and likely to come for MorphOS. I expect AmigaOS on Tabor to squeeze out the maximum possible video performance too over time.
  • »23.07.18 - 19:52
    waldiamiga
    Someone will help, the system has been able to be installed now to boot from the disk.
    qemu-system-ppc -machine mac99,via=pmu -m 1024 -device sm501  -boot d -prom-env "boot-device=hd:,mac_ppc32boot.img" -bios openbios-qemu.elf -vga none -device ide-hd,drive=hd-drive,bus=ide.0 -drive file="morphos.img",if=none,id=hd-drive,format=raw -net nic,model=rtl8139 -net user
    MorphOS.pl
  • »23.07.18 - 21:50
