Blender 2.37a released
    roschmyr
    Posts: 206 from 2003/2/20
    @Acill
    no need for a script, add the tooltyp CLI to the icon
  • »02.09.05 - 17:13
    aliem
    Posts: 85 from 2003/12/11
    here is a nice icon+script http://projects.morphwiki.org/blender-icon.lha
    enjoy it ;)
  • »03.09.05 - 01:49
    Posts: 1915 from 2003/10/19
    hey nice job, but mine was a funny icon. You can replace it by just
    renaming it to yours.
  • »03.09.05 - 02:24
    warface
    Posts: 653 from 2003/2/24
    I've used Blender for a small project some time before, so I was curious to try out the MorphOS version. Despite being an alpha it's more than perfect! Awesome! All my previous files worked, so I've made a small article about it. It's in hungarian but check out the pictures :-)
    http://snews.vim.hu/pages/200406/blender.htm
    Even using the OSX Blender icon for it :-)
    There is only one thing I'd change: please make Blender open on a separate screen, as I couldn't reach the windows and the ambient screen behind :-)
    Truly AWESOME job!
  • »03.09.05 - 17:13
    CISC
    Posts: 619 from 2005/8/27
    Tried right-clicking the depth gadget (and as for Ambient, how about adding iconify)? ;)
    - CISC
    [ Edited by CISC on 2005/9/4 2:03 ]
  • »03.09.05 - 19:02
    aliem
    There is the option "-w" that will open Blender in a window, but there are some bugs in refresh, so you could get black parts on the gui.
    To try it just:
    " blender -w "
    bye
  • »04.09.05 - 00:35
    Furvert
    Posts: 83 from 2004/4/20
    > CISC
    I have to agree with this, and having an art program in a window isn't really any better. That's one of my complaints with Pixel. I do alot of multitasking when I work and being able to flip from screen to screen for something is alot easier for me. It's one reason I went with Amigas for the last 19+ years, and now Peg2/MOS and will NEVER go to winblows.
    Furvert
  • »04.09.05 - 11:28
  • scf
    scf
    Posts: 54 from 2003/6/3
    After running blender in window, move it a bit outside screen and back. Refresh will be ok again.
  • »04.09.05 - 11:57
    Krashan
    Posts: 1107 from 2003/6/11
    Ha, I have a new avatar, of course done with Blender :-) as an exercise. All I need now is the possibility to load TrueType fonts into Blender. The builtin font is nice, but it is only one ;-).
  • »04.09.05 - 12:36
    aliem
    Another way to open Blender in a custom screen is:
    1. create a new screen in SysPrefs
    2. NewShell :)
    3. Send this shell to the created screen using Mui's prefs or the "popup button"
    4. execute blender ;)
    NOTE you can only do it with muicon (i think)
  • »04.09.05 - 15:40
    Yomgui
    Posts: 348 from 2004/8/31
    I've added the screen chooser and I've re-eabled python, there are lot of scripts now to import/export yours scenes!! 8-)
    I've fixed many bugs too...
    I'll release tomorrow I think.
    I'm waiting about a freetype libto re-enable the Truetype support too.
    Yomgui
    And now... next project!
  • »05.09.05 - 10:44
  • psd
    psd
    Posts: 35 from 2004/3/21
    Thanks for your work Yomgui, i really like blender. :)
  • »05.09.05 - 17:01
    Lanza
    Posts: 2 from 2004/11/27
    Yomgui
    IIRC, TTEngine is based on Freetype. It may help...
  • »05.09.05 - 20:43
    warface
    You mean the invisible depth gadget in the rightmost upper corner of the screen? It cycles the screen, not the window, so the content of ambient screen and underlying windows cannot be accessed :-)
  • »05.09.05 - 22:19
    CISC
    It doesn't help at all, he needs Freetype2, not TTEngine, anyway, Freetype2 pretty much builds OOTB anyway, no problem...
    - CISC
  • »05.09.05 - 22:57
    CISC
    No, with the -w option you get a proper window, then there's a depth gadget for Blender itself...
    - CISC
  • »05.09.05 - 22:58
    Yomgui
    I cannot release a new version tody, I've spent to much time on the compilation of freetype (sources downloaded here: http://www.freetype.org/index2.html ).
    But it's work now with it (static version)
    [ Edited by Yomgui on 2005/9/6 19:18 ]
  • »06.09.05 - 11:08
    Krashan
    Does it mean I will be able to create 3D objects out of TrueType fonts? I will be more than happy then :-)
  • »06.09.05 - 11:17
    Yomgui
    I think its.... yes! :-)
    ...so, you could be more happy
  • »06.09.05 - 12:17
    Yomgui
    New release done! (Python too)
    - Python script enable
    - Partial support for Python OpenGL wrapper
    - Trutype2 support
    - Screen chooser
    - Launchable from Ambient
    - load/save in blender are working now (but some python script are not yet fixed)
    - Many others fixes....
    And every think at the same place:
    http://yellowblue.nerim.net/files/python-2.4-mos_5d-20050908.lha
    http://yellowblue.nerim.net/blender/arc/blender_2.37a-mos_bin-20050908.lha
    [ Edited by Yomgui on 2005/9/9 11:46 ]
  • »09.09.05 - 10:46
    Posts: 1068 from 2003/3/24
    Thanks for this new Version!
    One question, is it possible to set a Screen resolutin
    as a tooltype or in a configfile?
  • »09.09.05 - 12:10
    Yomgui
    You can set the env var BLENDER_SCREENMODEID with the mode id of your choice (in decimal format)
    You can use the -modeid <id> option too (<id> in decimal format too)
  • »09.09.05 - 13:11
    Where i have to put it as tooltype in the Icon???
    Sorry for my noob question.
    And where can i change the position of the camera in
    Blender can't find this information in the Blender
    tutorial?
  • »09.09.05 - 14:39
    Krashan
    Just select the camera object with RMB and grab/rotate as every object.
  • »09.09.05 - 15:30
    Gelb
    Posts: 148 from 2003/3/4
    I found this to be of exceptional help when having to deal with apps that are trying to simulate M$-Windows full-screen mode like APDF and apparently blender too.
    You might be tempted to try it out.
  • »09.09.05 - 18:02
