Posts: 1193 from 2003/2/24
The client only goes online, when all blocks are processed to flush them and fetch new ones.
That's one problem. I want it to (try to) go online only when it's possible
Last time I tried, the client got a bit stuck trying to get online, when it couldn't...
You can even run offline and fetch blocks manually.
I dcon't want to do that... I want to be online 24/7
The thing is, I know when it can get online (weekends + mon-fri 21.00-08.00) but how to make the client know that aswell? Maybe esiest way is to get it fetch blocks once a day... But I really can't experiment with it while it can't connect...
Well, guess it's time to write some dos scripts this weekend...
