ytSearch
    Posts: 1390 from 2010/1/6
    YT-Search.hwa V0.8 seems to have a problem:
    Breaks with "Unknown notification "Mouse Move" in line 24! - (Aktuelle Zeile: 617 - in Funktion Create App)"
  • »05.05.25 - 06:37
    igracki
    Posts: 471 from 2003/2/24
    Please install the latest RapaGUI plugin!
  • »05.05.25 - 12:50
    igracki
    Here is a standalone version of ytSearch, it has all plugin's included and don't need the Hollywood Player.
    Download it here
  • »05.05.25 - 12:57
    With new RAPAGUI it works. But standallone-version does'nt!
    Gives a suspect error: Icon file "ytsearch.info is an unknown/unsupported format! Datei: YTsearch.hws (aktuelle Zeile 128 - in Funktion LoadIcon.
    I tried it from Shell and there is no ytsearch.info.... and where should YTsearch.hws be?
  • »05.05.25 - 14:02
    ChrisC
    Posts: 37 from 2025/3/1
    Standalone gives me 'Error initialising cURL!' but it is installed and runs on shell fine. What are the install instructions for the standalone? It just comes as an executable. Also the Hollywood version gives a code 10 error, unknown command yt.rexx
    [ Edited by ChrisC 05.05.2025 - 19:02 ]
    Power Mac G5 11,2 Dual 2GHz
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
    MorphOS 3.19 (Licenced)
  • »05.05.25 - 15:29
    igracki
    Sorry, I forgot to put the icon into the archive, just copy any icon you like as ytSearch.info.
    YtSearch.hws is only the name of the source file. You don't need it.
  • »06.05.25 - 06:42
    igracki
    Hmm, the cURL error is strange, since I linked HURL plugin into the standalone version.
    Please run Snoopium to find out what's missing.
    ytSearch needs an installed yt.rexx to play the videos!
  • »06.05.25 - 06:45
    ChrisC
    i do have yt.rexx installed so i am not sure what i am missing, i did change the rexx library when i did a fresh install for my G5. I will take a look a little later with snoopium but the rexx error has me a little confused.
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »06.05.25 - 07:46
    igracki schrieb:.....
    That I've tried first - makes no difference!
    SnoopDOS points to an open-problem of Amissl_v111a.library!! Why that? This is from AOS 68K. Does'nt Hollywood use native SSL from MorphOS?
    Btw: I've installed Amissl too, because IBROWSE needs it.....
    [ Editiert durch Amigaharry2 06.05.2025 - 20:23 ]
  • »06.05.25 - 16:08
    Posts: 2220 from 2003/2/24
    You have linked hurl.hwp version 1.1, which is ancient and requires AmiSSL. Update your Hollywood:LinkerPlugins/ppc-morphos/hurl.hwp to version 2.0.
  • »06.05.25 - 17:10
    igracki
    Thanks jPV!
    We need a Grunch Database for Hollywood Plugins...
    Here is a new archive with hURL v2.0 linked.
  • »06.05.25 - 18:40
    Works now! Fine!
  • »07.05.25 - 14:57
    igracki
    What happens if you type "rexx:yt.rexx" in a shell?
  • »10.05.25 - 14:08
    igracki
    Try "Rx rexx:yt.rexx".
    Do other arexx scripts are working?
    [ Edited by igracki 10.05.2025 - 21:35 ]
  • »10.05.25 - 16:19
    Papiosaur
    Posts: 2625 from 2003/4/10
    Do other arexx script are working?
    I don't know.
    I have "Command returned 5/1: <This space intentionnaly left blank!>"
    [EDIT] When i drag and drop the script in a shell it work. Si i have a problem with rexx: path i think.
    When i do "cd rexx:" i obtain System:S>
    I have Assign rexx: sys:rexx ADD in user-startup.
  • »10.05.25 - 16:32
    igracki
    Could you try "assign rexx: sys:rexx". Without the ADD?
    And then be sure that yt.rexx is in rexx: respectively in sys:rexx.
  • »10.05.25 - 17:43
    Papiosaur
    ok, now it work!
    i have removed the ADD and when i write cd rexx: i obtain System:rexx>
    Cool, i will test ytSearch tomorrow and i will finalize the pack :-)
    Thanks Thomas for your help!
  • »10.05.25 - 18:00
    Uhm... REXX: points to SYS:S/ and if anything expects something else, it's wrong.
  • »10.05.25 - 21:10
    igracki
    I have since ever assigned REXX: to sys:rexx/ because I don't want the ARexx scripts in sys:s/.
    sys:s/ is IMHO only for amiga-dos scripts.
  • »11.05.25 - 15:42
    But there is no SYS:rexx directory in the standard installation of MorphOS or AmigaOS, so better not to expect users to have an assign pointing to it in your scripts/programs.
    [ Edited by jPV 11.05.2025 - 22:08 ]
  • »11.05.25 - 17:05
    Posts: 12572 from 2003/5/22
    You already had that last year ;-)
  • »11.05.25 - 20:55
    Papiosaur
    @Andreas_Woolf: Yes, it's the same problem...
    @Thomas: i think it will be better to install all Arexx script to S: to remove this problem of assign...
    I think ytSearch should work better after that. Maybe you must do changes (or maybe not)?
  • »12.05.25 - 05:02
    igracki
    Since the yt.rexx archive doesn't have an Installer script, the user can copy the rexx scripts where he wants;)
    But I can change the directory structure inside the archive, so the arexx scripts will be copied to sys/s/ insteadif the user copies the "sys" directory.
    Also I'm strongly against putting all scripts into s:.
    But that's not my problem:)
    I think under AmigaOS there was a sys:rexx/ directory!?
    Maybe MorphOS doesn't have it because there is no real arexx support?
    Since you have to copy the AmigaOS rexx.library.
    Or does it changed sometime?
  • »12.05.25 - 09:11
