MorphOS Developer
Posts: 3325 from 2003/3/5
In the screenshot can be read "--disable-network" and "Failed to initialize a hardware accelerated renderer". This will change hopefully.
Yes, I've only wanted to see if it builds/works with minimal modifications. Networking should be relatively trivial to fix, so I am not concerned about that (poll vs select). Ideally, the plan would be to drop SDL2 and simply write a MUI/overlay renderer.
