Posts: 1228 from 2010/1/6
jacadcaps schrieb:
@ Amigaharry2
Downloads always start in the default directory. When you use Save As..., the file will be renamed/copied to your chosen destination. This is done after the download has finished.
This won't work with big files, If default path is RAM: - PC will run out of memory! I've some files more than 7GB to download. At moment I need to define a HD-Partition for download (which I don't like for smaller, temporary files)
With V7.1 and all versions before 7.0, downloads where directly be stored in choosen path of "save-as" requester.....
Tried V7.1-backup again, to be sure, and it works as expected......
Edit: I found out something very estonishing: I tried now to download a file with OWB, and the download requester stands suddenly on the path, I have set as default in Wayfarer (CacheCD:), despite default path in OWB is RAM:!!! How can this be? I set RAM: manually in OWB download-requester and loaded down a file. Back to Wayfarer, suddenly the requester accepts now different pathes and loads down directly there!! What's going on here? How can OWB influence Wayfarer and vice versa?
