    Mozzerfan
    Posts: 101 from 2016/10/5
    Jaca,
    Are shoutcast mp3 radio stations supposed to work ?
    The play button on this site doesn't play anything.
    http://directory.shoutcast.com/
    [ Edited by Mozzerfan 01.05.2021 - 03:46 ]
  • »30.04.21 - 23:43
    NewSense
    Posts: 1560 from 2012/11/9
    NewSense wrote: The crash showed the Acineralla video player had "Frozen". I cannot send the Crash report as it has locked up the whole requester save mechanism of the filesystem, even the Crash report failed to Send, so I am having to report this information via OWB v1.25.
    jacadcaps wrote: This is now fixed.
    I will download v1.16 and go from there, . . . and . . . I do appreciate all your considerable (understatement) efforts on Wayfarer, along with all the others involved in making/suggesting improvements.
    NewSense wrote: I know you said your focus is on YouTube, but I thought you should know about these sites as well, as Formula1.com is a mainstream worldwide accessible sport interest website ...]
    jacadcaps wrote: Formula1.com is too slow even on my 2.3GHz G5. It's serving very demanding high-bitrate streams. It won't work on a mini, period.
    I know you think that about formula1.com, but then why does it work OK with v1.12 on my 1.5GHz MacMini? :-?
    As videos load OK, and the video and audio work in sync and the video streams in quite a watchable way.
  • »30.04.21 - 23:53
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    jacadcaps a écrit :
    Make sure VP9 is off if YT is taking up too much CPU. You can set that in Settings > Media > VP9 codec support.
    VP9 is deactivated in prefs.
    Unfortunatley, YouTube experience using desktop version (not using Safari/iPad spoofing) is quite unusuable and playing medias from it is painfully slow : only sound with CPU toping at its max, when video finally starts it is jerky and 1/3 of the bottom is missing (I have to move the page to have the whole video appearing but it too much CPU intensive) and sometimes it finally crashes (bugreport sent).
    I'll revert to using Odyssey/YT.rexx with MPLayer for YouTube and still be using Wayfarer for usual surfing.
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »01.05.21 - 04:30
    igracki
    Posts: 463 from 2003/2/24
    You can also use YT.rexx with Wayfarer, if you have SmartClipboard.sbar installed.
    Then you just need to copy the url to the clipboard from context menu.
  • »01.05.21 - 05:42
    Posts: 43 from 2021/4/18
    I tested v. 1.16 with X5000 but cannot get Youtube videos running... If I click the red/white start arrow on the video, I get just a black window.
    I have Mediaplayback enabled, and have tested both with and without MSS. Spoofing is set to Safari/iPad. Are there any other settings which should be enabled or disabled? I have disk cache disabled (0MB) as I have 2 GB RAM.
  • »01.05.21 - 05:45
    ernsteiswuerfel
    Posts: 570 from 2015/6/17
    Regarding youtube video formats... As far as I gather there are h264, vp9 and dav1d. vp9 seems 'standard' but does YT provide any video in any of these formats? Will this shift in the future?
    On PPC Linux vp9 is the most problematic. Quite some endian issues and it does net pass the testsuite at all on ppc. dav1d passed it's testsuite with ease on my G4 but is rather slow on the other hand, lacking Altivec optimizations. h264 fares quite well on ppc/x86/x86_64 but has lowest quality.
  • »01.05.21 - 08:53
    Posts: 3251 from 2003/3/5
    What graphics card do you use?
  • »01.05.21 - 14:24
    Yes and it used to work. It seems that now this particular website doesn't work at all, not just in Wayfarer. I've tried it in Vivaldi and Safari and neither were able to play anything - the server request that's supposed to retrieve the MP3 stream address seems to be failing.
  • »01.05.21 - 14:56
    Radeon HD 5450 (1 GB).
  • »01.05.21 - 15:27
    zukow
    Posts: 650 from 2005/2/9
    Probably overlay isnt supported in this card. Does MPlayer work in Overlay mode?
  • »01.05.21 - 16:41
    I am afraid you are out of luck - this card doesn't do overlay which is currently required. There's some plans for alt display mode but no ETA yet.
  • »01.05.21 - 17:25
    Cego
    Posts: 738 from 2006/5/27
    Live streams on YT don't work. Any plans to support this? It would be nice if you could also give a short answer to my Proxy question. Thank you
  • »01.05.21 - 23:29
    Yes, live streams need a bit of extra work. I do want to support them, eventually.
    Proxy isn't really on the todo. Perhaps if I have a little more spare time.
  • »02.05.21 - 00:28
    Posts: 1358 from 2010/1/6
    I've a very strange issue with a 17" Powerbook 5.7. (A1107). This PB is a "hybrid" with PB 5.9 (A1139). Its motherboard is from A1107, but has a 1680x1050 display (instead of regular 1440x900).
    Try to play YT-videos gives only the first picture of the movie, but then it does'nt start to play it! Nothing more happens!
    I use exact(!) the same config as on my second PB, which is a 15" PB 5,6. (A1106). On this PB there are no issues and YT-videos a played perfect.
    I copied complete Wayfarer-directory and put cgxvideo.library to Mossys:libs - so there is no difference in installation between this two PBs.
    Both are runing MOS 3.15 and have PPC 7447A/1.67GHz-CPUs with Altivec.
    Maybe interresting:
    I know that older MOS-versions do have driver-problems (Radeon) with this PB, so that a "special driver" was needed at that time (thanks to MOS-Team). Later versions of MOS does'nt have that issues any more.....can't remember when it switched - think it was MOS 3.10.........
  • »04.05.21 - 20:16
    The difference must be in Wayfarer's media settings and or cookies then. The next version will hopefully simplify this by adding a million more confusing media options :)
    In better news: got YT Live streams to play today. Sorry for poor quality of the shot.
  • »04.05.21 - 23:15
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Ha! Sounds good! Thanks jacadcaps!
    IKE
  • »04.05.21 - 23:26
    No chance to get YT running on this PB. When starting video first picture is shown, then it stops and does nothing. Tried to start it from a virgin MOS-Installation, spoofing as any browser possible - does'nt go at all!
    Put same installation/config to a Mini and the second PB: runs flawless......
  • »05.05.21 - 09:18
    @Amigaharry2
    Is MediaSource support on or off?
  • »05.05.21 - 09:49
    Yes, is on!
    I have a PEG2 3xG5, 2xMini, and 2xPB. All oft them do well, only this f***ing PB won't do. Everywhere the same installation. As I wrote above, it seems, that this PB is a bit "special". Not only the screenresolution is different to the 5,7-Series - also firmware has some "special issues" (e.g. if trying to boot from a USB-stick - won't create a runtime device, limited to <4GB-Sticks and some other funny things).
    I think this is a problem of this special hardware.
    Edit:
    For some seconds I could now play a video (after killing all cache and settings-entries). But after first interaction (increasing sound) it stops and could not be started again. Also no any other video can be started now. It's like soemething blocks it. Very strange! I'll do some more tests.
    Im not sure, but I think that this issue does'nt occur with Wayfarer 1.12. Unfortunately I have no V1.12 anymore to test....
    [ Editiert durch Amigaharry2 05.05.2021 - 15:17 ]
  • »05.05.21 - 11:17
    Did you try pressing pause and then play? It sometimes helps if some internal states don't get correctly propagated.
  • »05.05.21 - 12:42
    Yes, I did all possible! What I also recognized: it takes a rel. long time till video is shown as "ready to play" (much longer then on the other PB).
  • »05.05.21 - 13:20
    No idea, really. If 1.17/1.18 doesn't fix this, we'll have to try some targeted debugging.
  • »05.05.21 - 13:52
    Good news:
    I've made a 3.15-iso with my keyfile and cgxvideo.library inserted. After playing around with Wayfarer-settings it plays now videos!! Very strange, because I've tested it on my USB-installation, which contains also only the ISO.....
    So I have now to figure out what's wrong with the installation on HD. Does Wayfarer save any configs outside its directory (except MUI)?
    And a 2nd thing I've to test: Now the PB is connected with Ethernetcable - the other tests are done with WIFI/Atheros Device...
  • »05.05.21 - 14:16
    Does Wayfarer save any configs outside its directory?
    No.
  • »05.05.21 - 15:17
    Pfft! It'srunning now. Reason was a incomatibility in Prefs/Env-arc/MUI. Killed all entries there and copied back only the content of
    the ISO.
    I don't know which entry exactly was the problem - I'm glad to solved it......
    [ Editiert durch Amigaharry2 05.05.2021 - 20:26 ]
  • »05.05.21 - 16:25
