Posts: 610 from 2011/11/30
Thanks a lot Jaca! Update went smooth.
Couple of suggestions:
1) Is it possible to add a context menu item on right click url address bar for "Paste and Go" (which is also located on Edit menu)?
2) Is it possible to have an auto notification for new version instead of manual check?
3) Can the "find" bar be moved at the bottom instead of up by an option on the Settings?
4) Is it possible to add a trashcan icon at the end of the url bar which will store the history session (say last 20 tabs which were closed) or this is related with the broader history capabilities already discussed?
Anyway, great stuff as always :)
