    Posts: 2095 from 2003/6/4
    jacadcaps schrieb:
    Coming with MorphOS 3.22:
    Youtube
    Dual core/dual CPU utilized in G5 Macs, 4 cores on Mirari. Video, audio, image decoding offloaded to the additional cores.
    Bamm!
    Deeply impressed. As said, still happy about the JIT speedup and now a steady supply of groundbreaking improvements. Wow, wow, wow!
  • »05.09.26 - 22:06
    Posts: 12575 from 2003/5/22
    Wow, that's insane :-D Must be a decade or so since I heard of bigfoot's successful attempts at running something tangible on further cores AMP/ASMP style.
    What about the 2nd CPU in PowerMac Dual-G4, or 3rd and 4th cores (2nd CPU) in Quad-G5, or 2nd to 4th core in X5000/40?
  • »05.09.26 - 23:45
    Posts: 3339 from 2003/3/5
    More in due time. I don't have all of the hw you've listed, so it's unlikely all of those will be supported.
  • »06.09.26 - 00:23
    NewSense
    Posts: 1619 from 2012/11/9
    jacadcaps wrote: Coming with MorphOS 3.22: Youtube
    So, will there be a v3.21 to fix the demuxer issue, or will the MOS Dev. Team be going straight to v3.22?
    jacadcaps wrote: Dual core/dual CPU utilized in G5 Macs, 4 cores on Mirari. Video, audio, image decoding offloaded to the additional cores.
    So, does that mean that the tasks to action the video, audio, image decoding are run as separate threads/tasks, or is it implemented in a different way?
    I thought using the additional core(s)/CPU(s) was not possible with Amiga type systems?
    Is this your, or someone else's idea to implement this functionality?
    What speed increase is there to the system's CPU(s)/Core(s) when this method is implemented?
  • »06.09.26 - 02:37
    Posts: 2586 from 2003/2/24
    @NewSense
    Pretty sure there will be a 3.21 release focussing on bugfixes and a 3.22 with new features some time later. At least thats how it has been done in the past and is supposed to be done.
    Timeline for both is anybody's guess as usual.
    These extra tasks will run outside of ABox, so no (direct) calls to legacy API no way to run existing apps this way (obviously) but also no restrictions imposed 40 years ago.
    What isn't clear whether these "QBox" ( *runs*) tasks are still 32Bit or 64 which would completely rule out anything G4.
    Not that Dual_G4 would make much sense in the 1st place with the limited number of people running these and the hard limitation to either 2 or 1.5GB.
    [ Edited by Kronos 06.09.2026 - 04:52 ]
  • »06.09.26 - 03:38
    Posts: 1099 from 2004/9/23
    Kronos broke the internet. Again!
  • »06.09.26 - 05:42
    Fair enough. In case of support for Mirari's 3 additional cores, is one video decoded by all 3 cores in parallel (= triple decoding speed and thus ability to decode videos one core would be too slow for), or still just one core per video (= up to 3 videos in parallel)?
  • »06.09.26 - 11:34
    Divinity
    Posts: 532 from 2009/9/8
    Youtube
    Great news, Jacek!
    I have a request: since this will also tax the cores or additional CPUs depending on the different PMacG5 models, it would be helpful to have a utility to increase the fan speeds on these Mac models as needed, something similar to this software https://crystalidea.com/macs-fan-control/download or this one https://www.morphos-storage.net/?id=1604130 which would allow for better management of everything via a GUI
    Incidentally, unlike the 7.3 and 7.2 models, the 11.2 models have a shell command for fan control that isn’t usable in MorphOS (if I remember correctly, this command is called PowerMac7FanControl), so it would be very useful to have something that works for all PMacG5 models and even better if everything could be adjusted via a GUI
    What do you think?
  • »08.09.26 - 11:24
    I think you're confused. That tool you've linked to is obsolete. MorphOS has proper fan control code for all of the models you've mentioned.
  • »08.09.26 - 11:48
    Divinity
    sorry, but I’m not sure which one you’re referring to
    If you mean ‘Thermals’ in the Utilities folder, when I run it on my PMacG5 11.2 I get the message: ‘This architecture is not currently supported by Thermals’.
    What should I use to view and adjust the fan speed settings?
  • »08.09.26 - 19:28
    Fan control is outside of Thermals app. That's just a frontend to display stuff.
    Either way, this has nothing to do with Wayfarer.
    [ Edited by jacadcaps 09.09.2026 - 00:28 ]
  • »08.09.26 - 23:28
  • ASiegel
    Posts: 1399 from 2003/2/15
    (Thread clean up.)
  • »15.10.26 - 07:09
