    Posts: 3291 from 2003/3/5
    @Amigaharry2
    Could also be some local (on-disk) cache issue... But it's normal that a different network connection may serve you a different website, essentially, since it'd be coming from a different CDN.
  • »13.08.25 - 23:48
    NewSense wrote:
    Or is there some hardware "trick" that it accomplishes on little-endian systems that it just can't on big-endian CPUs, even if the code was converted to big-endian code?
    No.
    Even if I somehow managed to write all the necessary bits to make Web Assembly work (all JIT stages, etc), Ruffle would still assume it's running on little endian. You'd have to fix Ruffle itself and compile it to WebAsm. This is all doable, of course, with a team of people that have infinite spare time.
  • »13.08.25 - 23:52
    NewSense
    Posts: 1596 from 2012/11/9
    @ jacadcaps - I thought you'd say something like that in response to my comment.  8-D
    However, thanks for taking the time to reply - a lot easier, and less time consuming than converting Ruffle !! ;-)
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »14.08.25 - 02:54
    ppc-grinch
    Posts: 30 from 2025/7/17
    If one wants to view Adobe Flash content, then download the .swf file and play it locally on your system. AmigaOS4 has Gnash, but I don't have AmigaOS4.
    I would recommend Flash Player 1.4/1.6 by Maxim Ilyn from 2008, but I've tried the program and it is less than ideal. You don't get play/pause/rewind or any controls like that, the .swf just autoplays. I tested two or three .swf files when I tried Maxim's program, however long ago that was, and, if I recall correctly, autoloop is not even an option. Audio continues playing, but the video stops and doesn't loop, so that's a bummer.
    There's one other option that I have yet to try, and that's swfplayer 1.4b6, hosted on Aminet. It's from 2005 and compiled for 68k AmigaOS3, so it should work fine on MorphOS, but the developer prefaces that the software is in beta, so it has kinks. I do not know if using it is a worse experience than using the newer Flash Player 1.4/1.6 by Maxim Ilyn.
    Mac Mini G4 1.5 Ghz, ATI Radeon 9200 64MB, 1GB RAM
  • »14.08.25 - 13:34
    Posts: 916 from 2004/1/24
    jacadcaps wrote:
    10.5 is now out. WebKit was rebased to latest stable WebKitGTK 2.48.5.
  • »15.08.25 - 19:57
    Posts: 1382 from 2010/1/6
    @jacad: Could now test Amazon again here in Vienna: Works now! I've done absolutely nothing on installation - just booted and it runs...! Seems really to be a temporare Provider-Problem (again...!).
  • »18.08.25 - 17:47
    Primax
    Posts: 208 from 2021/7/2
    A question:
    Do you also have websites where Wayfarer runs at full capacity? I have the traffic indicator at the top of the menu, and it is completely maxed out: no more bars, just blue.
    This happens more often lately. This is an example:
    https://www.osnews.com/story/143070/amibrowser-the-chromium-engine-running-on-a-linux-host-talking-to-a-68k-amiga-application/
    By the way, no problems if I ran that with OWB.
    My question: Is this due to my X5000? Or is it the same for you? If so, can someone explain why?
    And above all: what can I do in such a case? Wayfarer then no longer responds.
    Thanks!
  • »19.08.25 - 02:22
  • ASiegel
    Posts: 1396 from 2003/2/15
    @Primax Being incompatible with newer web standards (ECMAScript 6, for example) has a few benefits. The biggest one is that most common tracking solutions will not work, thus do not permnanently run in the background and monitor your mouse movements, etc.
    While OSNews advertise at the top that they are no longer running ads, there are still currently 9 tracking scripts active on this website.
    Aside from this, you might be blocking ads and trackers in OWB but not Wayfarer. Put differently, different browser configurations could play an additional role as well.
  • »19.08.25 - 07:02
    @Primax
    It's the donation box (ha ha). Once you block ko-fi.com the site is super-fast. Feel free to complain to os-news' admins. The iframe spikes the CPU on Safari/macOS as well.
  • »19.08.25 - 11:43
    Primax
    Irrespective of the specific example, my main question was what I can do if Wayfarer hangs because the content is too complex, etc.?
    Can I just wait and see or can I interrupt it somehow?
  • »23.08.25 - 04:31
    Normally it'll eventually let you close the tab - that's what happens with osnews for example.
  • »23.08.25 - 11:52
    NewSense
    @ jacadcaps - It would be even better if there was a way to "interrupt" break-into a loading webpage and just close it, if required, like any page that we come across with "Cloudflare" control, as we won't be able to access such a content controlled webpage anyway.
    Having to wait until a lengthy JavaScript heavy webpage has loaded, can also seem to be toooo long quite often anyway to just be able to close it! :-(
  • »24.08.25 - 02:35
    Work on Wayfarer 11 progressing...
  • »30.09.25 - 23:43
  • »01.10.25 - 08:09
    waldiamiga
    Posts: 96 from 2007/7/25
    Wow!
    I'm glad you're still developing your software.
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »01.10.25 - 11:54
    analogkid
    Posts: 715 from 2004/11/3
    Great :) thanks.
  • »02.10.25 - 03:22
    tolkien
    Posts: 565 from 2013/5/29
    Fucking machine. Thanks Jaca!
  • »02.10.25 - 10:59
    First post with Wayfarer 11. There appear to be some graphics issues, so it'll be a while before a release, but things don't look too bad for now.
  • »20.10.25 - 10:57
  • MDW
    MDW
    Posts: 497 from 2003/7/25
    Interesting, very interesting. :-o We're waiting for more details.
  • »20.10.25 - 12:01
  • MDW
    MDW
    jacadcaps wrote:
    In case anyone is interested in how big of a challenge the MorphOS port is, here's a cleaned up patch:
    https://github.com/jacadcaps/webkitty/compare/master_2.50.0...morphos_2.50.0
    What can I say... Adapting this WebKit to MorphOS is a huge effort. An unbelievable number of changes and adjustments. I have no idea how you handle it. :-)
    Summary of the changes for those who haven't checked GitHub:
    #if OS(MORPHOS)
    // Something unimaginable.
    #endif
    πŸ˜ƒπŸ˜ƒπŸ˜ƒ
    [ Edited by MDW 21.10.2025 - 15:19 ]
  • »21.10.25 - 14:17
    MoerBoer
    Posts: 239 from 2019/10/15
    That’s crazy!
    Thank you so much for all the work! I’m sure it can be very hard at times to keep going with so many changes.
  • »21.10.25 - 15:15
    Posts: 477 from 2019/5/9
    Because I upgraded my Peg 2 to 1.8 GHz, I want make it again my main home machine
    I installed Iris and last version of Wayfarer
    @jacadcaps: thanks for your great work!
    Iris works OOTB with my provider, Wayfarer is great but I cannot play youtube video ( Error 153 Video player configuration Error)
    Please, what is correct setup to play videos? Need I some scripts ?
    In old OWB I have script youtubeFulscreenFix and it works ( slowly, but for music it is enough )
  • »28.10.25 - 16:31
