  • man
    man
    Posts: 136 from 2019/11/11
    ok
    so it s javascript problem when you want to change email
    simple i tried to click right and ok
  • »07.12.23 - 09:37
    Posts: 3336 from 2003/3/5
    @man
    I'm sorry but I cannot read your mind. I have no idea what it is you've tried to do exactly. A URL would help, for the start.
  • »07.12.23 - 14:53
  • man
    man
    no problem
    it s only when you use paypal and the email is not working for me but when i click the mouse ( the right) work after all
    thanks
  • »07.12.23 - 16:20
    NewSense
    Posts: 1618 from 2012/11/9
    When I visit Wayback machine - actually this page - CU Amiga CD11 then the images for the CD covers are reversed as though its images have been flipped. I feel sure that the website would not have done this, but I have a feeling that Wayfarer v7.0 is mishandling it somehow? :-?
    In fact the whole frame to view the images in is reversed, as the numbers in the frame are reading back to front as 1 to 2 is horizontally reversed, and the loading button is across on the right, whereas it would be on the left usually - as in the Western world we read from left to right, and this all seems to be the opposite way round - like looking at the image from the viewpoint of staring at it reflected from a mirror.
    Anyone else come across anything else of a similar nature? ;-)
  • »08.12.23 - 05:44
    @NewSense
    Oh, this is quite interesting. It's like that even in much older Wayfarer builds, though. As it also happens in WebKitGTK, I've made a bug report on webkit.org and will let them deal with it.
  • »08.12.23 - 11:39
    Posts: 1390 from 2010/1/6
    Another strange thing: Requester for download-path has no function. Path is always set to prefs, no matter what's choosen in requester.
    [ Editiert durch Amigaharry2 08.12.2023 - 19:07 ]
  • »08.12.23 - 17:06
    @Amigaharry2
    Which one? There's 3 requesters that can set the downloads path and there's 2 downloads paths stored (regular one and download-as one).
  • »08.12.23 - 18:22
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    @NewSense
    If you click on the little cross in the white circle (top left), the images will be flipped as they should be. But it's really weird.
  • »08.12.23 - 20:24
    This one:
    As you can see, partition CacheCD: is choosen for download, but it is ignored and stored nevertheless to RAM: (which is set in prefs...).
    Previous versions of Wayfarer does'nt do that.
  • »08.12.23 - 20:34
    NewSense
    jacadcaps wrote: Oh, this is quite interesting. It's like that even in much older Wayfarer builds, though. As it also happens in WebKitGTK, I've made a bug report on webkit.org and will let them deal with it.
    Thanks for the quick response, and it must be nice, for once, to be able to "hand-off" the work to others, rather than having to DIY! 8-D
    IIRC often when extracting images from MS based, sometimes MSWord based/saved PDFs the images that you got out of such a PDF were also extracted in horizontally reversed format! :-?
    Is there any likelihood that all of this is a weird sort of endian issue? 8-D
    ghh wrote: If you click on the little cross in the white circle (top left), the images will be flipped as they should be. But it's really weird.
    Well as that's the closing gadget (which I'm sure you know) who would have thought it would swap the layout of the GUI on that webpage - that in itself is just too weird ... and it's no wonder I missed that "trick"! However, it's great that you found out that it did that, so thanks! 8-D
    ALSO ... I just realised that if you hover the mouse pointer over the arrowheads (< >) in the GUI the text that pops-up reads "Flip left", "Flip right" - and if you click on the gadgets the left-hand arrowhead it does nothing, and if you click on the right-hand arrowhead it moves the CD image into better view, but UPWARDS, not SIDEWAYS (Left-or Right), and if you then click on the left-hand arrowhead it does nothing, so the CUCD cover image remains out of view! You can of course use the scrollbar to bring the cover image back into view. Then, If you click on the "Thumbnail view" gadget then the images are made much smaller, and are then placed side-by-side, as it seems is the intention, but if you click on one of the images then they go back to being displayed one above the other, as before. If you use the circle gadget to move the images Up (Left) and Down (Right) in the horizontal slider then with the GUI the right way round the gadgets work as they should, but if they are back to front you have to click close to the first button to get the images to swap positions. So, the handling in this GUI is wrong ... very wrong, at least for we Wayfarer (WebKit) users. :-D
  • »09.12.23 - 03:58
    Primax
    Posts: 220 from 2021/7/2
    1) Obviously, kickstarter.com requires the confirmation that a human being is accessing it. When I try this website:
    https://www.kickstarter.com/projects/gamingchronicles/the-commodore-amiga-500-story-the-gaming-chronicles-ep-1
    then I can confirm it, but I am not forwarded. The request comes again and again...
    2) How can I get Wayfarer to stop playing a YouTube video? I can pause it via menu but where can I actually stop it?
    Thanks!
  • »09.12.23 - 11:55
    @Primax
    Cloudflare does not support Wayfarer (yes, it has to be this way around).
  • »09.12.23 - 16:56
    Version 7.1 is available now!
    - Rebased to WebKitGTK 2.42.3
    - Fixed a network thread deadlock when resuming downloads
    - Changed the '+' button to always adds tabs at the end
    - URL bar would stay empty when moving a tab to a new window, fixed
    - Selection redraw issues fixed
    - Added Save Screenshot to the Debug menu
    - Worked around and fixed reported crashes
    [ Edited by jacadcaps 13.12.2023 - 15:17 ]
  • »13.12.23 - 13:16
    Posts: 919 from 2004/1/24
    w00t! :-D
  • »13.12.23 - 14:21
    vulture
    Posts: 198 from 2008/2/4
    awesome!
  • »13.12.23 - 17:42
    Wow - Cool!! The requester does also now, what he should....
    To take a screenshot is also very usefull.
    Thank you!!
  • »13.12.23 - 19:27
  • man
    man
    youtube works perfectly now
    thanks
    not use chrome if you don t want the size of the video changing
    if you look a lot of videos then less memory too
    i dont use yt 2.4 for the moment
  • »14.12.23 - 16:54
    NewSense
    When I started up v7.1 of Wayfarer I got a system error flash and sound, that I never got when I used earlier versions of Wayfarer.
    Anyone else had this trouble, &/or know what might be causing it ... or more importantly how to fix it? :-?
    I had a quick look in the LogTool, but I didn't see anything obvious that was related to Wayfarer, but that is exactly when I seem to get the screen flash & system error sound - on Wayfarer v7.1 starting up.
    I have started up v7.0 and when I start it up I don't get the system error sound/flash that I do get with v7.1 ... v7.1 does start/load but I would have preferred to understand what was causing the issue rather than anything else.
    [UPDATE] Anyway, I ended up swapping over a fresh download-archive of the program and now having copied that into my original installation directory the fresh installation seems to have resolved the problem, though what the problem was I have no idea. :-(
  • »18.12.23 - 00:43
  • rms
    rms
    Posts: 606 from 2004/11/27
    Tanks very much for this new version, which runs very well here and much faster that previous versions, really great!
    Thanks a lot also for having added "Save as text..." and "Save as HTML..", very helpful for me!
  • »18.12.23 - 02:48
    Primax
    Again I tested behaviour of YouTube videos with Wayfarer 7.1: here, on a X5000, it stopping a video definitely does not work.
    I run a m.youtube video:
    - if I try to pause it via cmd+Enter, then the video pauses for 20 seconds. This way it should work?? If yes, how can I stop it??
    - if I try to pause it via menu, then the video only pauses for 5 or six seconds.
    Please, can anybody check this?
    Thanks!
  • »18.12.23 - 06:02
    Posts: 31 from 2022/8/17
    Thanks!
    I tested it on my G5 and I can stop it via clicking twice in the middle of the video (don't know if it's a desired behaviour). When I stop it, it stays like that until I click again in the middle of the video to continue playing.
  • »18.12.23 - 07:35
    The menu may not always work. It's meant as a workaround for sites that don't want to play on their own. Use normal YT controls and you'll be fine.
  • »18.12.23 - 12:42
    Wayfarer 7.2 is now available, with the WebKit engine just 4 days behind the release of WebKitGTK 2.42.4.
    2.42.4 addresses crashes in JavaScript, WebCore and several rendering issues.
    Please update using the Check for Update & Autoupdate functionality built into Wayfarer.
    Note: I've adjusted the maximum string length in WebKit to 64MB (from the original 2GB that makes no sense on 32bit architectures). While I do not anticipate problems, something might have broken. Do report if you find a site that worked OK with 7.1 but does not with 7.2.
  • »19.12.23 - 13:31
    Incredible!
  • »19.12.23 - 14:42
    Primax
    Honestly, I am bit confused because I had memorised that I should use the menu for fast-forwarding etc. But for stopping and playing I am supposed to use YouTube?
    At least, double clicing in the middle of the video worked! Thanks, DayWalker!
    There are not any proper YouTube controls. At least here, I cannot use the lower time slider. Does not work.
    Apart from that: thanks for the new version! :)
    PS: Wait!!! Just installed the latest version, and what shall I say? For the very first time, I can actually use the time slider!! It works! :)
    [ Editiert durch Primax 19.12.2023 - 20:57 ]
  • »19.12.23 - 18:51
