    Posts: 11 from 2021/5/5
    jacadcaps wrote:
    @Mach
    Does the same happen if you download and extract the new wayfarer.lha and run directly from the extracted folder? It sounds as if all of Wayfarer’s data files were missing.
    I found the problem: I had only extracted the 2 visible files to the new folder, not the entire contents. Thank you!
  • »01.01.23 - 18:31
    Posts: 3324 from 2003/3/5
    4.8 is now out to fix the socks proxy regression. Coincidentally, 4.7 and 4.8 appear to benefit from a recent cURL optimization enabling SSL certificate caching. This should make pages loading resources from multiple servers a lot less CPU intensive.
  • »03.01.23 - 00:50
    NewSense
    Posts: 1614 from 2012/11/9
    @ jacadcaps - You (and your team?) seem be constantly working on Wayfarer, and looking for aspects to improve it, which is really amazing. :-o
  • »03.01.23 - 03:48
    MoerBoer
    Posts: 239 from 2019/10/15
    Geez, it's incredible the amount of work that jaca and team put into this. It's really appreciated!
  • »03.01.23 - 06:19
    Cool_amigaN
    Posts: 776 from 2011/11/30
    @jacadcaps
    Well, let me repeat your words and emphasise on this: [...] should make pages loading resources from multiple servers A LOT less CPU intensive, as I confirm that there is a HUGE difference when loading multiple tabs! Thanks a million for this new version :)
    [ Edited by Cool_amigaN 03.01.2023 - 12:45 ]
  • »03.01.23 - 08:40
    @ Cool_amigaN
    Your disk I/O must be very slow if you're seeing a HUGE difference.
  • »03.01.23 - 11:45
    Blasterreal
    Posts: 41 from 2007/3/30
    Any one open https://chat.openai.com/ with wayfarer ? My powerbook always say "Human verification" ang high CPU usage.
  • »03.01.23 - 12:24
    Cloudflare does not currently support Wayfarer. Any site protected with Cloudfare will not work.
  • »03.01.23 - 12:38
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    I had strange problem with Wayfarer 4.7 and 4.8. SOMETIMES I can't close Wayfarer. The application works correctly, I am able to open tabs with websites, navigate, close all tabs except the last one. But if I use "Quit" option in menu, RCmd+Q or click close button on main window of Wayfarer - there is no effect. I can't close the application.
    Debug logs are clean.
    I noticed the problem three times. I am not sure but probably always in background GCC 11 was building huge project (CPU usage 100%). If I stopped the compilation, close FlowStudio, CPU usage was 0%, I still wasn't able to close the Wayfarer. After reboot Wayfarer works correctly.
  • »03.01.23 - 17:03
    @MDW
    Next time this happens, try to see what WkWebView processes are still around.
  • »03.01.23 - 17:23
  • MDW
    MDW
    jacadcaps wrote:
    @MDW
    Ok, I will check it. "Unfortunately" now everything works well (also during a compilation) and the problem is not reproducible.
  • »03.01.23 - 17:34
    Primax
    Posts: 214 from 2021/7/2
    MDW schrieb:
    I had strange problem with Wayfarer 4.7 and 4.8. SOMETIMES I can't close Wayfarer. The application works correctly, I am able to open tabs with websites, navigate, close all tabs except the last one. But if I use "Quit" option in menu, RCmd+Q or click close button on main window of Wayfarer - there is no effect. I can't close the application. ....
    I can confirm that. It happened here after playing an mp4 file inside Wayfarer.
  • »04.01.23 - 19:32
    Posts: 81 from 2020/5/1
    I have the same problem (already since 4.5 or 4.6); it just stalls on quit. Will check the WkWebView processes next time.
  • »05.01.23 - 07:14
    Posts: 1385 from 2010/1/6
    Since I removed Datacache to max. 2MB this problem does'nt occour any more.
    But there are serious problems in YT to play videos: Some Videos (not all!) won't start after commercial (eg. https://m.youtube.com/watch?v=4VoYpCsMoEo&t=613s) but works in OWB flawless.
    Others (https://m.youtube.com/watch?v=4VoYpCsMoEo&t=613s) will break after a few seconds (especially when useing forward or backward jumps)
    Prefs in Wayfarer are'nt changed.
  • »05.01.23 - 10:03
    @Amigaharry2
    Don't use Auto quality on YT and you'll be fine. I might be able to fix this, but no promises. Google does not follow MSE specs at all and does quality switching by randomly feeding you chunks from different video streams.
  • »10.01.23 - 11:19
    cip060
    Posts: 151 from 2010/7/30
    I noticed some deterioration of the general speed from 4.7 to 4.8
    I have an IMAC g5 2.1 Isight
    OWB is always significantly faster in all the things I do on the various sites both in downloading files and in terms of site viewing time and page scrolling
  • »10.01.23 - 13:19
    There have been literally no changes that would have an impact on performance between the two.
  • »10.01.23 - 13:33
    @Jacad: Thank you! Will try it!
  • »10.01.23 - 14:29
    cip060
    No I meant Before 4.7/4.8!
  • »11.01.23 - 06:52
    I cannot really say much without you providing any data to back this claim. All prevoius versions can be downloaded from wayfarer.icu/history.
  • »11.01.23 - 14:59
    Wetransfer (https://wetransfer.com) has issues again: Transfer won't start. Instead CPU goes most time up to 100%.
    Worked definitive 2 weeks ago.....think, they have added too much of this background-crap on their website!
  • »12.01.23 - 18:55
  • MDW
    MDW
    jacadcaps wrote:
    @MDW
    It occurs again. Reproduction steps are the same:
    1. Start long compilation in FlowStudio with G++11 - CPU usage almost all the time is 100%.
    2. Open Wayfarer 4.8.
    3. Open morph.zone webpage.
    4. Open next tab (Cmd+T) and open exec.pl. :)
    5. Progress indication on morph.zone tab stops (about 90%) - webbage is white.
    6. Progress indicator on exec.pl is loaded, I can scroll the website.
    7. I can't close both tabs but after many many clicks on close button I closed morph.zone tab.
    8. Exec tab works normally but I can't close the Wayfarer (Cmd+Q, Quit, close gadget on the window).
    On list of tasks in Scout I see:
    Wayfarer
    WkWebView:com.apple.WebKit.CryptoQueue
    WkWebView:com.apple.WebKit.IndexedDBServer
    WkWebView:curlThread
    WkWebView:LocalStorage
    WkWebView:org.webkit.DataURLDecoder
    If I clicked a link on webpage exec.pl, the Wayfarer crashed. I sent the crash report.
  • »25.01.23 - 14:53
  • ASiegel
    Posts: 1397 from 2003/2/15
    @MDW
    Do you have Adblock enabled? If not, would you mind enabling and trying again?
    exec.pl has a boatload of Javascript trackers running in the background. Perhaps there is some relation.
  • »25.01.23 - 17:28
  • MDW
    MDW
    ASiegel wrote:
    @MDW
    No, I don't use nay adblocks. The problem occurs not only on exec.pl. I often explore this webpage using Wayfarer and everything is ok. The problem occurs sometimes (very rarely) when in background CPU is extremely used.
  • »25.01.23 - 17:50
  • ASiegel
    The Javascript trackers found on exec.pl are used by many other websites.
    I perfectly understood that the issue only occurs when Wayfarer may be starved for resources.
    My proposed test was intended to help figure out if the issue is related to Javascript (said ad trackers).
  • »26.01.23 - 02:50
