    Posts: 3324 from 2003/3/5
    Version 3.8 is out!
    - Implemented basic drag & drop of web elements within a page
    - Fixed scrollbar positions after switching between tabs
  • »06.06.22 - 10:43
    MoerBoer
    Posts: 239 from 2019/10/15
    Geez, coding machine! Thanks!
  • »06.06.22 - 10:53
    Primax wrote:
    I had found only one page so far where it worked:
    https://www.heise.de/news/heise-spielt-Amiga-500-live-ab-12-Uhr-Neue-alte-Retro-Freundin-6659366.html
    Unfortunately, it doesn't work now either....
    I've email the result of my analysis to you but since others may stumble on this as well:
    Youtube now requires touch events when using the iOS / Android user agents. Video will either not start or you will not be able to seek since YT completely disregards mouse inputs.
    I'm working on mitigating this (by emulating touch events) in the next release, but there will be caveats to this.
  • »08.06.22 - 12:26
    Posts: 1354 from 2004/2/8
    A to kutafony!
  • »08.06.22 - 12:42
    The new Wayfarer release comes with following changes
    - Implemented ClearKey DRM support for HLS media streams
    - Implemented HLS stream quality switching accessible from the media popup
    - Added configurable touch events emulation (think Youtube-Mobile seeking slider)
    - Refactored the HLS player to allow MPEG-TS playback
    - Live HLS streams now start playing closer to the current time
    - Improved stream end position reporting to get some streaming services correctly skip to next stream after playing ads
    - Updated libcurl
    While not very popular these days, ClearKey encryption is still being used by some live streaming services. Wayfarer will now play those streams (https://tv.nrk.no for example).
    The touch events emulation makes it possible to seek on mobile Youtube again.
    wayfarer.icu
  • »28.06.22 - 12:50
    I'd like to thank amyren for sponsoring NordVPN so that I could take a look at several geo-locked services and get a chance to implement support for ClearKey.
    I would also like to thank everyone who donated to the project recently. Thanks a lot! You continue to keep me motivated.
  • »28.06.22 - 12:51
    FAQ updates: I've added instructions on fixing Youtube/iOS seeking and on using a VPN with Wayfarer (with additional hardware required). Take a look at
    https://wayfarer.icu/faq
  • »28.06.22 - 12:53
    First post from Wayfarer 4.0... The MorphOS betatesters just got access to a first build of a Wayfarer rebased onto the latest WebKitGTK 2.36.3. It will take between days to weeks before it's ready for a public release, though.
  • »04.07.22 - 14:31
    tolkien
    Posts: 578 from 2013/5/29
    Fantastic! You are the master!
  • »04.07.22 - 15:17
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    Great news!
    IKE
  • »04.07.22 - 16:23
    Posts: 81 from 2020/5/1
    The website claims Wayfarer 3.9 requires MOS 3.16. In fact it needs 3.17.
    So after Wayfarer 3.2 hanged while downloading the ISO for 3.17 (and downgrading to Wayfarer 3.2 not working), which means I cannot longer start Wayfarer, I'm now downloading the 3.17 ISO via OWB.
  • »30.07.22 - 10:35
    discreetfx
    Posts: 403 from 2003/7/26
    New versions will soon require MorphOS 5.0. McBill would be jealous!
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »31.07.22 - 19:24
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Version 4.0 feels faster on my G5 regarding page loading times.
    @jacadcaps: Would that be a side effect of the Webkit 2.34 -> 2.36 upgrade or did you add some additional code of your own? Or is it just my imagination? ;-)
  • »31.08.22 - 13:23
    tolkien
    It seems faster each new version is released. True or false but fantastic anyway!
  • »01.09.22 - 15:10
    It's certainly nothing I've done :) That said, WebKit evolves quite dynamically, so it's possible they've optimized some stuff between the two snapshots.
  • »01.09.22 - 15:44
    matt3
    Posts: 784 from 2004/2/10
    Feels a bit faster to me also on my G5.
  • »01.09.22 - 16:36
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Confirmed, it's faster here as well :) Jaca you are the man!
  • »01.09.22 - 16:48
    Wayfarer 4.1 is now available for download. I've rebased to WebKitGTK 2.36.7. Since 2.36.8 was released only yesterday, you can expect 4.2 within a couple of days. Still, don't hold updating - 4.1 should fix several crashes inside base WebKit that got fixed in the WebKitGTK branch.
  • »17.09.22 - 21:00
    NewSense
    Posts: 1614 from 2012/11/9
    @ jacadcaps - Brilliant support, and updating increments, you're a man (& Piru 8-)) to be proud of ! 8-D
  • »17.09.22 - 22:02
    tolkien
    Man! One day you will be update it faster than the webkit team! XD
    Fantastic Jaca.
  • »17.09.22 - 22:19
    bennymee
    Posts: 136 from 2004/4/14
    Thank you!
  • »19.09.22 - 06:33
    Wayfarer 4.2 with WebKit codebase updated to WebKitGTK 2.36.8 is out now!
  • »23.09.22 - 11:11
    matt3
    Thank you!
    Works perfect APU...
  • »23.09.22 - 11:36
    NewSense
    @ jacadcaps - Yet another "fresh as a daisy" update .... fantastic work ... really awe inspiring. 8-D
    Wondered if you've managed to made any in-roads into fathoming out how to 'outsmart' the Cloudflare security processes as yet, so we can load such integrated sites up when required to access certain websites in our day-to-day lives? :-?
  • »23.09.22 - 13:12
