Iris - An upcoming E-Mail client blog
    Posts: 3336 from 2003/3/5
    Iris 1.47 and Contacts 1.5 are now out!
    Iris 1.47
    - Fixed offline downloader getting stuck on a disconnected session
    - Fixed a race condition in the address cache shutdown code
    - Fixed a crash on quit
    - Improved SSL certificate validation
    - Updated WebKit to 2.48.3
    - Updated WebKit-related libraries
    - Switched to GCC15
    Contacts 1.5:
    - Fixed an issue with passing UTF8 encoded strings via Arexx
    - Updated to work with older versions of openssl3.library
  • »23.07.25 - 12:30
    Posts: 1390 from 2010/1/6
    Wow! First Wayfarer, now Iris......thank you!
  • »23.07.25 - 16:39
    tolkien
    Posts: 582 from 2013/5/29
    Is there a way to have fixed sizes in the columns (SUBJECT, DATE etc) of the emails list?
    Yes, I can resize them but when close Iris and open again they autoadjust at the content text.
  • »07.08.25 - 05:25
    Primax
    Posts: 220 from 2021/7/2
    Is it possible to set an option in Iris so that I can see the links when I hover over them with the mouse?
  • »07.12.25 - 06:20
    Click right mouse-button when you hover over....
    @tolkien: Late, but....: that can be saved by saveing MUI-Prefs in Iris.
  • »07.12.25 - 08:42
    Iris 1.48 now out with updated WebKit and a fix for Outlook login slowness.
  • »09.12.25 - 15:49
    Super! Will test it immediately....
  • »10.12.25 - 06:25
    Primax
    Thanks!
    @Jacek
    If you answer a mail, then there are always four empty lines between "on 2025-12-17 xyz wrote.." and the content of the mail to be answered.
    I had reported that a while ago, please have a look at it and if possible, fix it. Thanks!
  • »18.12.25 - 08:09
    @ Primax
    This depends on your response settings (top/bottom post mode).
  • »11.02.26 - 11:32
    Iris 1.49 is now out!
    - Fixed message search to skip disabled accounts and folders immediately instead of timing out
    - Fixed calendar popup window time/hour sliders' max values
    - Added some additional guards against exceptions in calendar date/time parsing code
    - Improved attachment filename handling when editing emails
    - It's now possible to paste an image from clipboard into an email
    - Added a workaround for broken ICS files sent from Outlook where some lines would be CP2152 encoded
  • »11.02.26 - 11:33
    Iris 1.51 is now out!
    - Fixed text cursor not reappearing after the message writer window was inactive
    - Clearing the signature in the Signature editor will now remove it completely, previously saved signatures that only contain a newline character are now silently dropped
    @ Primax
    The latter change should fix your empty lines issue
    [ Edited by jacadcaps 20.03.2026 - 12:41 ]
  • »20.03.26 - 11:38
    Iris 1.52 out now!
    - Fixed enter key not scrolling contents in the text editor
    - Reduced executable size of Iris and helper apps by a few MB
  • »26.03.26 - 12:24
    Posts: 23 from 2025/3/16
    Hi Jacadcaps,
    Could we expect synchronization of contacts and calendar in Iris? With Gmail and Outlook?
  • »29.03.26 - 13:19
    Calendar is somewhere on the TODO... No plans to add uploads of contacts for the time being - you can only download them from Gmail.
  • »29.03.26 - 19:58
    Primax
    @ Primax
    Thanks for the updates!
    Unfortunately, there are still four empty lines between:
    Am 2026-03-26 schrieb
    >mail content
    And the cursur is just in the line of "Am 2026-03-26 schrieb...."
    Shouldn't it a line ahead...?
    Thanks!
  • »01.04.26 - 17:55
    analogkid
    Posts: 722 from 2004/11/3
    Thanks for this update!
    Iris still gives "SMTPCommandError - Error while executing command 'DATA' as error when sending/replying emails from my Posteo account. Do you have an idea what this could be related of?
  • »02.04.26 - 02:53
    Probably found a bug in IRIS or I do something wrong:
    If showing a attatched file (text or graphics) in IRIS and try to print out, allways the mail itself is printed, but not the attatched file.....
  • »17.07.26 - 05:48
    Primax
    @jacadcaps
    Please update the FAQ of Iri, since it now requires MorphOS 3.20.
    Unfortunately I updated Iris - after I checked the FAQ - and cannot use it any longer :(
  • »09.08.26 - 04:31
    Piru
    Posts: 622 from 2003/2/24
    Is there some reason why you can't update to MorphOS 3.20?
  • »09.08.26 - 09:21
    Primax
    Yes, the installation on a X5000 via USB stick has a bug (bootcyrusplus.img).
    I have already told Frank.
  • »09.08.26 - 11:28
