Iris - An upcoming E-Mail client blog
    Posts: 2971 from 2003/3/5
    Tom01 wrote:
    Can you fix the Window-Refresh-Problems and add Copy & Paste?
    Hey Tom, not sure what you mean by refresh problems. Copy & Paste works via command key + c/v if you mean the email view or editor...
  • »29.08.18 - 19:27
    Iris beta 38 is now available (link): changes are mostly focused on UI and optimizations this time.
    - New Folder screen menu in the main window with Mark All Messages as Read, Empty Folder and synchronization functions
    - Separate window menus for main window, reading, writing and other windows
    - Activity LEDs in the folder tree
    - Added Select All/Unread/None to messages list context menu
    - Added a context menu to the html editor & reader
    - Small delay in refreshing the sent folder when finalizing sending emails, fixes some issues with sent emails not appearing in the folder
    - Writer window has a verification requester when closing the window / terminating Iris
    - Added a privacy policy to the Aboutbox window
    - Optimized setting flags on multiple messages at once
    - Fixed a case where duplicate entries could show up in a messages list after sync
    [ Edited by jacadcaps 12.09.2018 - 16:09 ]
  • »12.09.18 - 20:27
    ernsteiswuerfel
    Posts: 545 from 2015/6/18
    Nice! A very substantial update in terms of usability!
    And nice to see myself being productive in the bug tracker. ;-)
  • »12.09.18 - 23:15
    Tom01
    Posts: 179 from 2009/9/20
    The WebViews are not refreshing, when enhanced Display is disabled.
    I can't enter Text in the New Message Web-View.
    I get no Context-Menu in the WebViews.
    I am using Beta 38 and VNC-Server.
  • »05.10.18 - 17:28
    Do I read that right that the refresh is broken while viewing stuff via the VNC Server?
  • »05.10.18 - 19:24
    Posts: 779 from 2007/10/23
    In email view you can try to copy text without any marked text...
    BTW is it possible to see the complete mail header?
    The default Email recipient is invalid@noaddress, is this useful?
    [ Editiert durch polluks 07.10.2018 - 23:28 ]
  • »07.10.18 - 20:16
    There's no way to see the full header... I'll add something later on.
  • »13.10.18 - 22:03
    Iris beta 40 is now availble from tunkki.
    This beta introduces the ability to move messages within an IMAP account and adds a more modern icon set from icons8.com. Some synchronization bugs have also been fixed.
  • »13.10.18 - 22:04
    I get
    Iris(imaps://XX.XX@gmail.com@imap.gmail.com:993/IrisFolderCacheSynchronizeJob): EINTR: signal occured before transmission
  • »14.10.18 - 01:29
    At a first glance this looks like a networking issue. Run Iris with trace argument from command line and send me the ramdebug log. The trace contains metadata of your emails (but no actual contents).
  • »14.10.18 - 07:52
    Indeed, today is works flawlessly. No blue LED or "FAIL 1".
  • »14.10.18 - 10:58
    Tom01
    About says Beta39.
  • »17.10.18 - 17:01
    Tom01 wrote:
    About says Beta39.
    Yeah, sorry for that. Beta41 is up with some minor fixes.
  • »17.10.18 - 21:16
    And for some fun facts:
    Iris is now over 42000 lines of (my own) code and has almost 300 Objective-C classes & protocols. This excludes all the work that went into porting libraries and modifying OWB.
  • »17.10.18 - 21:27
    Posts: 2720 from 2003/2/24
    This is really some truly incredible work!
  • »17.10.18 - 22:38
    Posts: 2794 from 2006/3/21
    As I was reading through the previous couple pages of this thread, I began thinking to myself, wow, what a huge task jacadcaps has taken upon himself. Probably much more work than you had initially anticipated doing to create a new MorphOS email program.
    I just relocated to begin seeing different doctors, so cash is a bit tight right now, but I will definitely send you a donation for all your hard work on this project, as soon as I can. I hope other users will do the same, when they are able.
    Thanks again for all you contribute to us MorphOS users.
  • »17.10.18 - 22:59
    Tom01
    @jacadcaps
    Yes, that must be a Problem with VNC Server.
    Can you check that?
  • »23.10.18 - 16:39
  • rms
    rms
    Posts: 599 from 2004/11/27
    I still get the following line in log:
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderCacheSynchronizeJob): Authentication error.
    Is there anything wrong?
    Regards
    Christoph
  • »25.10.18 - 05:44
    Basically accessing each IMAP folder means a new connection - which means authenticating separately. No idea why this fails for you. Could be anything from a bug in the implementation in Iris from a Netstack issue...
    I’ll try to add some more verbose info in the next release...
    Are you using the OAuth authentication?
  • »28.10.18 - 08:06
    @Tom01
    Could you try with Enhanced display being off?
  • »28.10.18 - 08:07
  • rms
    rms
    Yes, AFAIR, this was configured automatically during setup of account, it says OAuth Provider = GMail and then Authentication = OAuth2
  • »29.10.18 - 05:15
    ernsteiswuerfel
    Beta V41 is working very well. I got nothing to complain about. ;-)
  • »29.10.18 - 10:44
  • rms
    rms
    I had Iris running for 24 hours in iconified state and this morning, I get these lines in the log:
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderCacheSynchronizeJob): ENOTCONN: not connected
    Iris(imaps://christoph.poelzl@gmail.com@imap.gmail.com:993/IrisFolderJobOpen): ENOTCONN: not connected
    Iris(imaps://christoph.poelzl@rmsvideo.ch@server1.weboffice.ch:993/IrisFolderJobOpen): Socket is not connected.
    Normal?
    Best regards
    Christoph
  • »10.11.18 - 05:38
    @rms
    Try "telnet imap.gmail.com 993" to check a connection at all.
  • »12.11.18 - 20:38
    Looks like a disconnection. Nothing you should worry about.
  • »26.11.18 - 22:14
