Posts: 170 from 2014/7/15
neoman wrote:
I try hard to get SimpleMail 0.40 running but no way. He downloads the folder names but does not download or show *any* message. The lists are just empty. IMAP and SMTP are configured correctly. I use no SSL to avoid problems. I can't send a new mail. I can write it, but when I like on 'Send now' nothing happens.
Someone got an idea what's going on?!
Regards,
neoman
I have also some problems with SimpleMail 0.40 with Yahoo Mail and GMail. I've configured Yahoo Mail as is working in my other systems using imap. I can fetch mail and all folders show the mails but I cannot send mail. After about a minute SimpleMail says "Service not ready". That is using SSL. If I uncheck the secure option in the settings, then I get "AUTH failed. User couldn't be authenticated. Please recheck your settings."
For GMail, it simply won't work. Fetching mail gets the message "Failed to connect to the server".
I have installed AmiSSL 1.1 and 3.6
Is anybody using Yahoo Mail or GMail with imap in SimpleMail?
PowerBook 5.8 MorphOS 3.18
Mac Mini MorphOS 3.18
