email server?
    bash64
    Posts: 977 from 2010/10/28
    Any chance of an email server being ported?
    Something simple like dovecot or even iredmail.
  • »10.04.13 - 02:23
    Krashan
    Posts: 1107 from 2003/6/11
    You mean an SMTP server? I guess the demand is not high for such an application. It assumes you will run your MorphOS box 24/7, isn't it?
  • »10.04.13 - 03:50
    bash64
    sure. i already run my gaming laptop 24/7.
    its been on for 3 years now without a problem.
    I was going to run iredmail in a vmware session.
    I need mapi also, not just smtp.
  • »10.04.13 - 12:59
    Piru
    Posts: 624 from 2003/2/24
    You run your own domain(s) and want to set up the morphos box as the MX?
  • »10.04.13 - 16:35
    bash64
    sure. sounds good.
    ready to buy my own domain name.
    use DynDNS.
  • »11.04.13 - 02:56
    Piru
    bash64,
    sure. sounds good.
    use DynDNS.
    The MX should have a high availability. Some linux or BSD system would likely work better.
  • »11.04.13 - 11:07
