machine code cartridge for vice
    amiga4001
    Posts: 454 from 2006/11/16
    I want to try assembler coding for the C64 with the help from vice.
    Vice works ok,but I need a cartridge image for the machinecode.
    I tried The final cartridge 3 but can't seem to get the pointer to move to select basic and then goto monitor by typing MON..if I am correct?
    Is there no image off a cartridge which does functionkeys or starts in Basic....
    The build in machine code program off vice uses another syntax ...?
  • »04.04.13 - 17:34
    Britelite
    Posts: 68 from 2003/6/4
    amiga4001,
    You could try Action Replay 6, it has a menu that works with functionkeys.
    I also think there was a keyboard shortcut in Final Cartridge 3 that got you in to Basic, but it's been 15 years since I used one, so I can't remember :(
  • »05.04.13 - 03:42
    Jupp3
    Posts: 1193 from 2003/2/24
    It's a lot easier if you use a cross assembler, such as cc65. That's what I used for my Payback 2013 intro.
    Of course it's way more oldskool doing it with a machine code monitor instead, but if you just want to "do as you would on a real C64", then you could still use assembler.
    And yes, you can also use vice's machine code monitor, I don't think that's much different from what Action Replay VI offers anyways.
  • »06.04.13 - 22:13
    bash64
    Posts: 972 from 2010/10/28
    I programmed all my assembly using moses64.
    I am sure you can find a copy out there somewhere or I can mail it to you.
  • »07.04.13 - 02:10
