Will E-UAE be updated for MorphOS?
    XDelusion
    Posts: 602 from 2010/10/27
    Aghh so it is for sure that if this project is directly tied to MorphOS and not just OS 4.x then?
    If that's the case I need to stop spending my tax return on Amiga and Atari stuff and put some towards this MUCH NEEDED cause. I have having to resort to Windows for a half way decent Amiga emulation experience...
    ...well that is emulation that goes beyond single disk game emulation.
  • »20.02.11 - 03:38
    Simon
    Posts: 809 from 2008/7/6
    it's going to be open-source ... that's good enough for me.
  • »20.02.11 - 05:22
    ChrisH
    Posts: 167 from 2009/11/26
    @XDelusion Quote:
    I thought the bounty page made it clear enough, but if not then read the first post on the developers blog:
    http://euaejit.blogspot.com/2011/02/hello-and-welcome-on-e-uae-jit.html
  • »21.02.11 - 16:28
    pampers
    Posts: 1073 from 2009/2/26
    Which part is not clear enough?
    MorphOS 3.x
  • »21.02.11 - 17:40
    XDelusion
    I had only read about it on Amiga.org previously, now that I read this I see the angle.
    It is being developed on OS 4, but not coded in a way to make it OS 4 dependant. Therefore a MorphOS port would be a possibility but not a certainty. Gotcha.
  • »22.02.11 - 21:47
    Posts: 12572 from 2003/5/22
    Also there it's said:
    "The JIT version will automatically become open source and other PPC OS will hopefully be able to benefit from the work as well."
    http://www.amiga.org/forums/showpost.php?p=616528
  • »23.02.11 - 07:46
    Posts: 3337 from 2003/3/5
    Of course it'll be opensource since E-UAE itself is GPL. It's nice of the author that he intends to make it easily portable.
  • »23.02.11 - 09:12
    Simon
    If he does this the way he promise he will, and a port for MorphOS doesn't materialize... only the MorphOS community itself is to blame. We can only give him the benefit of the doubt ( if there is any ) and give our support. I did support with 30€.
  • »23.02.11 - 16:35
    XDelusion
    Andreas_Wolf: I didn't say exactly what I read on Amiga.org now did I?!
    If I'd had read a part that made it clear to me that a MorphOS edition was being worked on side by side, or not, then I'd never have posted my question in the first place. ;)
  • »24.02.11 - 03:19
    You said you "had only read about it on Amiga.org previously". The message on amiga.org includes the sentence I quoted above. And I take it you meant that message as you took part in the thread that was started by that message.
    The part I quoted of the message on amiga.org implicitly says that "a MorphOS edition" is *not* being worked on side by side.
  • »24.02.11 - 09:03
    XDelusion
    I just KNEW you were going to respond to that! Ha ha ha! :)
    I'm just messing with you man.
  • »25.02.11 - 03:18
    Do you want to be my prophet then? ;-)
    Good to know.
  • »25.02.11 - 07:04
    XDelusion
    If your other one gets crucified, poisoned or something then sure thing! I'm just dying to be a martyr.
    So you know, and so I don't come across as totally daft (not that there is anything wrong with being simple). I don't keep the inet at home, so generally when I am on-line it is at a friends, at the local Library, or up town at the local coffee shop. Needless to say, this is a small town, and I tend to attract a lot of attention being the town eccentric and all, so usually when I'm trying to read or type, I'm caring on a conversation or trying to get rid of someone in the physical realm as well, so as a result, it becomes very hard to focus on what I'm reading or to pick up on my typos, so with that said, sorry if I come across as irritating.
  • »26.02.11 - 02:56
    >> Do you think there will be a new and improved version?
    > PUAE tries to continue where E-UAE left off:
    > http://github.com/GnoStiC/PUAE
    Now available for AROS:
    http://o1i.blogspot.com/2013/04/p-uae-v01.html
  • »04.04.13 - 07:08
