Download torrent files with MLDonkey from desktop
    Jupp3
    Posts: 1193 from 2003/2/24
    Just configured mime types for downloading selected .torrent file. Pretty obvious, but in case someone else hasn't figured it out how to do this (or the fact, that mldonkey can download torrents, just doesn't support magnet yet) :-)
    Ambient settings ->Mime
    Select application/x-bittorrent
    Add new action, set name to whatever you want. Add new command.
    Type: AmigaDOS
    Command string: copy %sp Work:Applications/Network/mldonkey/torrents/incoming
    (change mldonkey path, if needed)
    ...and that's about it.
    As always, takes a while before the download starts.
  • »06.03.13 - 10:57
    amiga4001
    Posts: 445 from 2006/11/16
    Thanks!
  • »07.03.13 - 04:57
