MOS stop booting ??
    VooDoo
    Posts: 189 from 2005/8/24
    Today have strange problem... Power on MacMini and after MOS boot logo have only black screen and lost monitor signal ... cant load MOS and dont know why..
    Last what I make is shutdown from menu , not install any sw,patches ,update or make change in user-startup or stratup-sequence...
    Any have similar situation and know how i can fix this problem ? thanx!
    Using last MOS on Mini 1.5 ghz!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »05.03.13 - 10:20
    caver99
    Posts: 131 from 2012/6/14
    Hi Voodoo,
    Have you tried booting off your cd and see if the partitions are still there and if you can access them?
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »05.03.13 - 11:36
    CountRaven
    Posts: 566 from 2007/12/10
    Yeah boot from CD and check the partitions.
  • »05.03.13 - 12:04
    Posts: 1368 from 2010/1/6
    This behavior I had sometimes in case of corrupt poseidon-prefs (perhaps it's also your problem).... delete them (sys:prefs/env-archive/sys/poseidon.prefs) and reboot.
  • »05.03.13 - 14:21
    VooDoo
    Problem is gone ! Have corrupted OWB 1.19 files on MOS partition... Fix it whit SFSDoqtor!
    Thanx for replay!
    A1200 sandwich
  • »05.03.13 - 14:42
    amiga4001
    Posts: 454 from 2006/11/16
    I had this issue also.
    And I get read/write errors on partition with owb.
    Sfsdoctor always works to get it going again.
    Do more people experience this behaviour?
    Or is my harddrive on it's way out?
  • »05.03.13 - 17:24
    pampers
    Posts: 1061 from 2009/2/26
    I've experienced the same on my PB some time ago. I thought that my hdd is getting old but strange that happend only with OWB.
    MorphOS 3.x
  • »05.03.13 - 17:40
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Just to avoid weird theories, OWB doesn't corrupt disks. But it often writes to the disk to save cookies, bookmarks, session, history, favicons, whatever (depending on your options, they can all be disabled).
    If you happen to run in parallel unstable applications that corrupt the memory, the write buffers might potentially be trashed and OWB could write garbage to the filesystem if you're very unlucky.
    The thing is OWB can easily be affected, becauseit eats a lot of memory, and statistically, it has more chances to get hit by corruption. :)
  • »05.03.13 - 18:02
