RunInDOSBox r1 released
    ChrisH
    Posts: 167 from 2009/11/26
    (Since I'm still awaiting approval of my news item...)
    RunInDOSBox allows double-clicked MS-DOS programs to be automatically redirected to run inside DOSBox.
    Note that eGame is compatible with RunInDOSBox, and provides a quick way of starting your (MS-DOS) games, no matter which OS you use.
    You can download RunInDOSBox from Aminet.
  • »07.02.13 - 08:00
    hooligan
    Posts: 1948 from 2003/2/23
    Hi. It is approved now.. don't know of news moderators excuse but I was having a fever of 41 for two days :)
  • »07.02.13 - 09:36
    pampers
    Posts: 1061 from 2009/2/26
    Works like a charm under MorphOS - thanks for that ChrisH!
    MorphOS 3.x
  • »07.02.13 - 15:15
