How to zip files?
    Cego
    Posts: 738 from 2006/5/27
    Hello there,
    is there a way to zip files with morphos? i couldn't find zip for morphos. the last version is from 2001 and i couldnt make that one work.
  • »02.02.13 - 07:37
    Posts: 1090 from 2004/9/23
    zip works fine
    zip newarchive.zip mossys:c/list
    or
    zip -r newarchive.zip sys:c
    Geit
  • »02.02.13 - 08:02
    Cego
    the filesize is correct, but ambient wont show the content.
    and right now it is zipping the directory too, but i just would like to have the files stored in work:te/ in the zip file. i tryed -D but it didnt work.
  • »02.02.13 - 08:16
    Posts: 12543 from 2003/5/22
    This thread may be of interest for you:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8712&forum=9
  • »02.02.13 - 08:47
    bash64
    Posts: 974 from 2010/10/28
    This might be stating the obvious but what about using DirOpus?
    It has built in commands for this that can be assigned to a button.
    There is a default archive button provided.
     :-D
  • »02.02.13 - 12:28
    > DirOpus [...] has built in commands for this
    DOpus comes with a *built-in* ZIP archiver?
  • »02.02.13 - 13:51
    bash64
    Well, if you go in and make your own button then yes.
    Select AMIGADOS, then the zip command, then the parameters to pass to it and save it as a button.
    I have made a lot of custom buttons for myself over time.
     :-D
  • »02.02.13 - 14:00
    How can this ZIP command be built-in when you have to select a ZIP command that is external to DOpus? Such ZIP command that works on MorphOS is what the thread opener is in search for, so I don't think your hint can help him with his problem.
  • »02.02.13 - 15:35
