How to configure screenmodes?
    Spidey
    Posts: 568 from 2003/2/24
    I've installed MOS1.4 and I want to have a 1024x768 60 Hz screen.
    I can't choose this screenmode so I have to configure it myself. Ok, I'm not experienced with this part, can someone help me out?
    I've got a Daewoo TFT monitor, it's range is somewhere between 40 KHz to 48 KHz and 50 Hz to 75 Hz
    Thanks,
    Spidey
  • »18.01.04 - 16:15
    Henes
    Posts: 507 from 2003/6/14
    Take a look at Docs/ModeEdit.pdf document in your system volume.
  • »18.01.04 - 17:19
    liquidbit
    Posts: 407 from 2003/10/12
    RTFM!
    :-D
  • »18.01.04 - 19:38
    Spidey
    Hi Henes,
    Thanks! :-D
    So stupid of me, always saw that Docs-dir but never opened it :-)
    It helped me with the information that VESA modes are more easy to change. So I changed a 800x600 VESA screen to 1024x768 and it is steady as a house!
    Next is to try a 1280x1024 screen :-)
    Thanks again,
    Spidey
  • »18.01.04 - 22:36
    Spidey
    Hi all,
    I can't configure a 1280x1024 screen. Well, the 1024-part is the problem. Could this be because I've a setting of a 48KHz monitor?
    Bye,
    Spidey
  • »18.01.04 - 23:03
    Black_Eagle
    Posts: 70 from 2003/6/5
    Well, with just the basic calculation:
    48000 (Hz) / 1024 (pixels high) = 46,875 (Hz)
    In other words, a monitor with horiz. freq of 48kHz at a screen height of 1024 can only have a vertical frequency of maximum 46,875 Hz, so if the monitor can't handle that you can't use those modes.
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »18.01.04 - 23:17
    Spidey
    Thanks for the calculation Black_Eagle :-)
    It's funny though. I saw this monitor running in 1280x1024 mode on a pc, how's that possible?
    Bye,
    Spidey
    ps: I'm running again from my Peg1 :-)
  • »19.01.04 - 23:01
    porneL
    Posts: 49 from 2003/7/17
    maybe it was in low refresh rate or interlaced?
    this text is here to confuse you
  • »20.01.04 - 23:12
    Toto
    Posts: 268 from 2003/4/20
    @Spidey
    I have a 17" CTX TFT monitor capable of 1280x1024@75Hz.
    This is what I did to configure the screenmodes:
    Select the highest frequency monitor in ModeEdit (monitor-85KHz) then save and reboot.
    Delete all the screenmodes in ModeEdit. Then test and select the VESA modes you want corresponding to your monitor's refresh rate (in my case it was VESA 75Hz) then save and reboot.
    Now you can select the screenmodes you have chosen.
  • »21.01.04 - 00:00
    Leon
    Posts: 93 from 2003/11/28
    @Toto
    Can you create and save your monitor? I use a 17" SONY S73B and select one of the default monitors. But I can't create and save a monitor with the specs of my monitor. I guess there is a bug in the Prefs program.
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »21.01.04 - 10:25
    Jupp3
    Posts: 1193 from 2003/2/24
    I guess that should not be done... In that way one might end up with MorphOS booting into screenmode that monitor is unable to display (Too high frequency).
    Select frequencies that are within monitors' specifications
    I'd add screenmodes manually, select refresh requencies and test every new screenmode before saving.
    IIRC, when editing screenmode, you can select "preset" values (resolution, frequencies) from the top of the window, use that.
    Then press "Test". If it displays ok, press ok, otherwise Esc and don't even think of saving that screenmode :-)
    Oh, if you don't know exact specifications for your monitor, find them with google
  • »21.01.04 - 15:01
    Toto
    @Jupp3
    Well it worked for me :-P
    When I selected the refresh rate that matched my monitor I wasn't able to select the 1024x768@75 and 1280x1024@75 16/24 bit screenmodes. I suspect that's the same problem Spidey has.
    I know it's not advisable to do but if you are carefull it works. By selecting the highest frequency monitor you can acces all the screen resolutions.
  • »21.01.04 - 16:08
    Jupp3
    ...including ones, your monitor can't display...
    Just select "New" in ModeEdit window, then select suitable screenmode from list, test if it works, and if it does, save it. Should be safer that way.
  • »21.01.04 - 17:04
    Toto
    @jupp3
    You obvisously didn't read my previous post very well where I wrote:
    'Delete all the screenmodes in ModeEdit. Then test and select the VESA modes you want corresponding to your monitor's refresh rate (in my case it was VESA 75Hz) then save and reboot.'
  • »21.01.04 - 17:12
