Strange behaviour Yam or MUI
    Tomo
    Posts: 92 from 2003/7/29
    a week ago I was talking with my wife and at the same I was answering some emails with YAM. Well, I will never do that again (Two things together)! Suddenly YAM shrinked to 1/6 of the wide of the screen. I can still change the height of the bottom, I can still move the main pane over the screen (1920 x 1080) but I can't change the width of the main pane of YAM. I can still open emails and change width and hight of all the other windows of YAM, but not the main pane. I tried to change settings in YAM but no luck.
    It jumped to this width while typing and answering my wife (it seems very dangerous to do that) . Did I type in a forbidden shortcut? I don't know......
    Regards Tom
  • »16.01.13 - 20:29
  • rms
    rms
    Posts: 606 from 2004/11/27
    no I don't think it's because you talked with your wife ;-)
    I had this but it got fixed, it was a bug in YAM not in MUI. Use the latest 2.8 of YAM http://yam.ch/downloads and it shouldn't happen anymore. Otherwise you can contact the YAM developers and submit a bug report.
    Regards
    Christoph
  • »17.01.13 - 03:47
    Tomo
    I even tried YAM2.9 but no luck, the same strange behaviour!
    I never had this before (I'm an old Amiga-user and i'm using YAM for years and years). I even tried an old backup (YAM2.4p) but it has now the same behaviour. I will contact the YAM-developers..... The strange thing is that it is only the opening (main)-window of YAM. All the other windows in YAM are working fine.
    Regards Tom
  • »17.01.13 - 07:44
    boot_wb
    Posts: 874 from 2007/4/9
    You could try deleting/temporarily renaming env:mui/yam1.prefs (or whatever it is called, should be obvious) if it's an MUI problem. That will reset all MUI prefs associated with that program to the global MUI defaults. If that works delte the envarc: equivalent to make it permanent.
    [ Edited by boot_wb 17.01.2013 - 10:32 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »17.01.13 - 08:31
    Tomo
    I tried your advice but it it did'nt help so I assume it is no MUI-related problem.
    Regards ,Tom
    edit: I've tried again but it seems to work now!. I will reboot with the ENVARC: MUI-settings deleted also. It looks promising. I'm wondering why it didn't work before, but if it is working normal again I will be happy!!!
    Regards Tom
    (and thank you for your advice!!)
    [ Bewerkt door Tomo 17.01.2013 - 13:19 ]
  • »17.01.13 - 10:13
