ZVNC problem with Powerbook trackpad
    boot_wb
    Posts: 874 from 2007/4/9
    I've just discovered Zapek's excellent ZVNC client, which allows mouse/keyboard sharing without the overhead of streaming display data to the client.
    Unfortunately, it seems that the trackpad on the Powerbook behaves differently from an ordinary mouse: when using trackpad, mouse cursor movements are not transmitted to the server (the pointer stays in the same fixed position), although mouse button-presses and keyboard events are still transmitted.
    If I use a USB mouse on the Powerbook, all works as expected.
    Has anyone found a workaround for this (aside from using a USB mouse connected to the powerbook)?
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »13.01.13 - 13:20
    Posts: 3336 from 2003/3/5
    Touchpad events use a new InputEvent subtype, so they won't work until zvnc supports that (unlikely I guess).
  • »13.01.13 - 14:58
    boot_wb
    Thanks for the explanation.
    I don't suppose it's as simple as replacing IECLASS_POINTERPOS in the source code with the new subtype is it?
  • »13.01.13 - 15:23
    Posts: 2577 from 2003/2/24
    You would need (in source) check for the new trackpad inputevent and transform that into whatever format is used in VNC protocol.
    Should be doable for anybody with basic Amiga coding experience and some time.
    [ Edited by Kronos 13.01.2013 - 19:00 ]
  • »13.01.13 - 15:55
    boot_wb
    @Kronos
    I have the time... just not the experience. ;-)
  • »13.01.13 - 16:17
    boot_wb
    Thanks to Jaca & Kronos for support on IRC, ZVNC will now work with Powerbook trackpad as well as a standard mouse. Just needed minor changes & recompile.
    Am just waiting for confirmation that it's ok to modify/distribute if its useful for anyone (the included license says 'Yes', but the copyright notice in the .readme says 'no').
  • »13.01.13 - 18:19
    boot_wb
    Just heard back from Zapek:
    Yes, zvnc uses the highly permissive do what the f**k you want to public license. Have fun!
    ZVNC 1.5.1 is now uploaded to Aminet, and should be available soon.
    [ Edited by boot_wb 14.01.2013 - 11:34 ]
  • »14.01.13 - 09:31
