Hooking up a MINI LACIE FIREWIRE COMPANION HARD DRIVE
    osco
    Posts: 680 from 2009/10/21
    PLUG and PRAY setup :-D
    It was an Ebay bargain and 160Gb back-up to the MINI.
    The first attempt was on the PowerBook because at the time it had OS 3.1 and the Ultimate Pack.
    Inoke the C:> helios_rom_start and behold the drive Unnamed appeared on the PowerBook :-P
    Now What?
    I tried to name it but NOOOOOOOO! it was write protected??
    I couldnt format it ...Ambient was ready but Noooooooo?
    Was there a magic Write Protect Tab like the old floppies???
    Fiddle some more and lost the Disk Icon :-x
    Cried a little and took it over to the newly upgraded 2.4 to 3.1 mini
    Dual boot to the the mac side to see if I had fried the Lacie.
    Nope it was there but only 300mb not 160gb and write protected.
    The Mac side has a disk utilty program and I was able some how to unmount it?
    Sitting quietly in the corner waiting for a blue butterfly or Kronos to dry my tears :-o
  • »27.12.12 - 23:10
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    NTFS formated disk drive ?
    If yes, install NTFS3G :
    http://blubbedev.net/blog2/index.php?/archives/3-NTFS-3G-for-MorphOS-released.html
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »27.12.12 - 23:18
    osco
    The Library has a tutorial on setting up an external USB drive. Will see if it can also do an external firewire drive?
    It recomends a fat 32 format done on another OS
  • »28.12.12 - 12:26
