Upgrading 2.4 to 3.1 with issues :(
    osco
    Posts: 680 from 2009/10/20
    Thank-you for the Blue! A dual boot with 2.4 and 10.5.8 on the mac side. When on the Mac side (since the initial installation) the opening window opens with a RED stop sign announcing the Disk "Boot" is "un-repairable"? The issue has been there but has been ignored by me. Both OS's have been in use for plus three years. Tried years ago to upgrade from 2.4 to 2.7 but failed. Tried to upgrade from 2.4 to 3.1 last night but failed again.MorphOS 2.4 booting instructions.
    "Boot text" from the Mac side
    In order to boot MorphOS on a Mac Mini you need to place the boot.img file
    on a HFS formatted partition called Boot. Each time the file is updated, it
    will have to be blessed with the HFSSetMacBoot command. This tells the
    OpenFirmware which file to load when booting.
    It is only possible to bless one file per partition. OpenFirmware can only
    read HFS or HFS+ formatted partitions of the internal harddrive.
    IWizard automatically creates a HFS Boot partition when installing MorphOS
    and places the boot.img and a bootinfo.txt boot script file on it. In case
    the harddrive is partitioned manually, the installation process will fail
    if a Boot HFS partition isn't found. By default MorphOS will boot using the
    settings from the bootinfo.txt file.
    IMPORTANT:
    OpenFirmware may sometimes be unable to read the boot.img if it's the
    only file on the partition, therefore it is best not to remove this file.
    You have to bless the bootinfo.txt file after editing it to make it
    bootable again!
    Bootinfo txt from the Mac side
    <CHRP-BOOT>
    <COMPATIBLE>
    MacRISC MacRISC3 MacRISC4
    </COMPATIBLE>
    <DESCRIPTION>
    MorphOS Bootstrap
    </DESCRIPTION>
    <OS-NAME>
    MorphOS
    </OS-NAME>
    <BOOT-SCRIPT>
    boot &device;:&partition;,\boot.img ramdebug
    </BOOT-SCRIPT>
    <OS-BADGE-ICONS>
    1010
    FFFF000000000000000000000000FFFF
    FF0000000000000000A5F1000000F8FF
    000000000000000000C1C7F5000000F8
    00000000000000002BC1C19D000000F8
    0000000000000000F8C19DC12A0000F8
    0000000000000000F8C19797F50000F8
    0000000000000000F7C1974F977200F8
    0000000000000000F7C19090BAC100F8
    0000F52BF7F82BF7DFC8B4B4BAC800F8
    00ABC8C1C7C8C8C8C25D569EC1C100F8
    00CFC1BB9DBB9796B47A00F52B0000F8
    0000F6A4C1974F9090C1F500000000F8
    000000004FF597BABABAF700000000F8
    00000000000079BBC1C1F500000000F8
    FFF8000000000000000000000000F8FF
    FFFFF8F8F8F8F8F8F8F8F8F8F8F8FFFF
    FFFFF7F7F7F7F7F7F7F7F7F7F7F7FFFF
    FFF7F7F7F7F7F7F7F7ABF2F7F7F781FF
    F7F7F7F7F7F7F7F7F7C8C8F7F7F7F781
    F7F7F7F7F7F7F7F756C8C2A4F7F7F781
    F7F7F7F7F7F7F7F7F9C89EC856F7F781
    F7F7F7F7F7F7F7F7F9C8C29EF8F7F781
    F7F7F7F7F7F7F7F7F9C89E7A9E79F781
    F7F7F7F7F7F7F7F7F9C89797C1C2F781
    F7F7F856F9F956F9FEC9BBBBC1C8F781
    F7ABC8C2C8CFCFC8C981FAA4C8C8F781
    F7CFC8C19EC29E97BBFAF7F856F7F781
    F7F7F8A4C89E7A9797C8F7F7F7F7F781
    F7F7F7F756F89EC1C1C156F7F7F7F781
    F7F7F7F7F7F77AC2C2C2F7F7F7F7F781
    FF81F7F7F7F7F7F7F7F7F7F7F7F781FF
    FFFF818181818181818181818181FFFF
    0000FFFFFFFFFFFFFFFFFFFFFFFF0000
    00FFFFFFFFFFFFFFFFFFFFFFFFFFFF00
    FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    </OS-BADGE-ICONS>
    </CHRP-BOOT>
    Boot Info
    Created November 17, 2009
    Modified July 6 2010
    Info is Mac OS Standard
    Dimly remembered there was thread on the site about this issue but no resolution
    Going on the Morph side to see what the partitions look like
  • »26.12.12 - 13:09
    Posts: 2581 from 2003/2/24
    Why would you want to muck around with partitions when you allready have a working 2.x on the HD ??
    Just boot the CD and let the installer "update" the 2.x install.
    Even if you decide for a "clean install" you should still be able to just skip the partition part of the installer (it will than just delete/format you old sys: partition).
  • »26.12.12 - 19:04
    Posts: 12572 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6647&forum=3&start=5
  • »26.12.12 - 21:31
    osco
    The installer fails to upgrade 2.4 OS .....Says it is not a valid DOS disk ???????
    the wIZARD POOFS with a green head..I cancel and another info box appears exclaiming what the wIZARD was looking for and was lacking? will try to UPGRADE A FORTH TIME and transcribe
    the wIZARD
    This is a loaded gun issue and its pointed at 120GB of data. I have a Lacie firewire that is write protected....how do you get it to write?
    Can you borrow the helios C commands and library to 2.4 from 3.1 ?
    Want to start the new year off right but NOOOOOOOOOOOOO :-D
    [ Edited by osco 26.12.2012 - 20:37 ]
  • »26.12.12 - 22:45
    osco
    Red stop sign still there...I followed the steps suggested but no change
  • »26.12.12 - 23:52
    boot_wb
    Posts: 874 from 2007/4/9
    Osco,
    I also get the same error message when (rarely) booting into OSX. Aside from the minor annoyance, it seems to do no harm.
    EDIT: @Andreas_Wolf - Just followed your link. Will give that a try...
    [ Edited by boot_wb 27.12.2012 - 13:45 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »27.12.12 - 11:42
    osco
    :bloons:
    Stop Sign Gone ty :-P
  • »27.12.12 - 18:08
    Posts: 2732 from 2003/2/24
  • »27.12.12 - 19:19
    dake
    Posts: 204 from 2007/9/14
    Wrong post.
    [ Edited by dake 28.12.2012 - 11:21 ]
  • »28.12.12 - 08:11
