MAME High Score saving?
    redrumloa
    Posts: 1424 from 2003/4/13
    Is there a way to have MAME keep high scores of individual games? TIA
  • »17.12.12 - 22:26
    Doffo
    Posts: 508 from 2010/10/14
    To my understanding... If the game itself supported it in real life, then yea... I believe most 80s arcades just wouldn't save the high scores.. The second the power was killed, the high score data went with it... A game that saved your high scores was Centipede..
    YUUUP!
  • »18.12.12 - 00:47
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    If the game doesn't save it in hardware itself, then the alternative option is to use a savestate... ctrl f7 / ctrl shift f7 to save restore.
    Reminds me i should really work on MAME again someday. ;)
  • »18.12.12 - 12:38
    redrumloa
    Fab,
    Thanks for the info.
    Are you aware of the bug in the ROM folder path? If it is changed to anything other than PROGDIR:ROMS, it doesn't work. Other than that it works fantastic on my mid range FW800.
  • »18.12.12 - 17:27
    Doffo
    Fab,
    Honestly anything you work on is great. Emulators just add to the fun of MOS :)
    YUUUP!
  • »19.12.12 - 03:14
