Sound notification of events in poseidon
    Brumiga
    Posts: 277 from 2004/4/3
    Hello,
    I have no sound notification of events in poseidon. Under Morphos 2.7 or earlier there was a notification sound, when inserting or removing a USB device, by poseidon. Then I looked around in morphos and MOSSYS but found no trace of the sound files used. I booted from the iso to check if sound notification of events there is or not, negative result. I do not even recall the format of the sound files, aiff wave 8/16 svx or another.
    Brumiga
  • »24.11.12 - 12:39
    Jambalah
    Posts: 820 from 2008/3/30
    Hello Brumiga,
    you have to activate notification sounds going in System Settings -> USB, clicking on PopUps (listed left) and select a sound for Connection/Disconnect action.
    The sounds used before are in SYS:Prefs/Presets/Poseidon but you can even take a look in Mossys:Data/SoundEffects for more sounds.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.11.12 - 13:15
    Posts: 611 from 2003/4/11
    The Poseidon effects have been disabled by default in MorphOS V3 afair. There are indeed some sound effects in mossys:data/soundeffects with various bings, dongs and klings. I guess most people didn't even notice yet ...
  • »25.11.12 - 07:57
