Posts: 1576 from 2012/11/9
I tried to load Parcel2go.com's website but it failed to load, and it seems the problem is related to SSL as the link automatically loads an SSL page, and eventually OWB throws out an error requester that indicates an SSL error, though this may not be the only reason that OWB 1.17 doesn't load the page/site.
Anyone in a position to look into what's causing this problem.
not working url: https://parcel2go.com
Trying to access this site I got the error requester:-
Unable to open 'https://www.parcel2go.com.'
Error 35:SSL connect error
Accessing the not Secure part of the site gives the error:-
Unable to open 'http://www.parcel2go.com.'
Error 56:Failure when receiving data from the peer
Hope this helps to track down what's causing the rejection of access to the site.
I'm using a Mac Mini with MorphOS 3.
fixed url off from topic
[ Edited by NewSense 13.11.2012 - 19:59 ]MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
