How to avoid automounting in boot
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello, since i have installed morphos 3.0, every time at startup i have the rest of my mac mini partitions showed on the desktop, and since with 2.7 it wasn't happening, how can i disable that on startup?
  • »19.06.12 - 11:04
    Posts: 3326 from 2003/3/5
    Run HDConfig and disable automount for a selected partition.
  • »19.06.12 - 11:22
    _ThEcRoW
    Thanks!!!
  • »19.06.12 - 12:03
    _ThEcRoW
    I tried what you said and the partitions don't show up, but the "boot" partition refuses to hide. Is this normal?.
    Thanks in advance!
  • »21.06.12 - 10:59
    Just tried this here and it worked OK - you sure the flag was saved correctly? It could also be that some reference to this partition causes it to be mounted later.
  • »21.06.12 - 12:42
    _ThEcRoW
    I checked with hdconfig, and it is unchecked as you recommended. The other partitions doesn't show, but the boot does. It doesn't harm showing up in desktop, but i would like to not show up there to avoid possible mistakes while doing something and mess with it by accident.
  • »21.06.12 - 16:11
    Tom01
    Posts: 187 from 2009/9/20
    You can put it away with the right mouse button menu.
  • »21.06.12 - 18:43
    _ThEcRoW
    How exactly?. Are you suggesting to delete it, or moving to another place?
  • »22.06.12 - 15:52
    Tom01
    No, it is "put away" :-)
  • »22.06.12 - 17:34
    scrAb_
    Posts: 62 from 2010/7/23
    How to disable automounting at boot for usb drives?
    I mounted a pendrive using Tools/Mounter and by mistake I set it to mount on boot.
    Now (obviously) at boot, a message pops up asking for the drive.
    How can I get rid of it?
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »02.11.12 - 18:44
    Henes
    Posts: 507 from 2003/6/14
    You just have to delete the mountlist (with no icon) created in DEVS:DOSDrivers/
  • »02.11.12 - 21:12
