Win7->VNC->MorphOS 3.1
    redrumloa
    Posts: 1424 from 2003/4/13
    How exactly?
    I have VNC Server on the Win7 system and added the local IP of the MOS box.
    Ram Disk:> MorphOS:Down/MorphVNC/MorphVNC 192.168.1.88/5900,PASSWORDHERE
    Connecting to '192.168.1.88/5900,PASSWORDHERE' port 5900
    net.c/doconnect(): Unable to look up host '192.168.1.88/5900,PASSWORDHERE'
    main.c/main(): doconnect() failed
    I can ping 192.168.1.88 just fine. Possibly router blocking the port 5900?
  • »22.10.12 - 19:56
    boot_wb
    Posts: 874 from 2007/4/9
    Try:
    MorphOS:Down/MorphVNC/MorphVNC 192.168.1.88 PASS foobar
    (Defaults to port 5900 anyway, but would be 192.168.1.88::5900 in any case from readme)
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »22.10.12 - 20:34
    redrumloa
    boot_wb,
    Readme, what readme?
  • »22.10.12 - 21:02
    boot_wb
    The one in the archive with the executable. :-)
    Linky
    Usage: MorphVNC HOST/A,PASS/K,FULLSCREEN=FS/S,DEPTH/K/N
    Host can be in 3 forms: Hostname, hostname:display or hostname::port
  • »22.10.12 - 21:58
    Dragster
    Posts: 99 from 2005/11/6
    I'd rather use TwinVNC...
  • »23.10.12 - 02:46
    pampers
    Posts: 1073 from 2009/2/26
    If you want to control your Win7 machine from MorphOS - RDesktop is the solution you are looking for.
    MorphOS 3.x
  • »23.10.12 - 07:07
