USB Joystick
    caver99
    Posts: 131 from 2012/6/14
    I have a ralphnet usb to 9 pin adapter and it is recognized under Poseidon stack as a hid and when i go to settings its there but how do i configure the stack so i can use the joystick under games and emulators.
    I have been trying for ages but cant seem to get it to do anything in i.e. e-uae.
    i have it set as joy1 and now i am lost.
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »18.10.12 - 15:15
    amiga4001
    Posts: 449 from 2006/11/16
    You must setup the config in the action part.
    First do the fire button..that one is easiest to do.
    For the 4 directions you have to set up the range in which the action must take place...
  • »18.10.12 - 18:09
    caver99
    in the action part:-
    1, Pointer(GamePad), 2, Game Pad, 3, [Extra}
    1,
    x axis 0 0 255 lin,abs,var,bitfield
    y axis 0 0 255 lin,abs,var,bitfield
    2,
    Button 1(primery/trigger) 0 0 1 lin,abs,var,bitfield
    Button 2(Secondry) 0 0 1 lin,abs,var,bitfield
    Button 3(tertiary) 0 0 1 lin,abs,var,bitfield
    Button 4 to 54 0 0 1 lin,abs,var,bitfield
    3,
    Initial Startup Actions 0 0 1 lin,abs,var,bitfield
    Disconnect actions 0 0 1 lin,abs,var,bitfield
    if i tick track incomming events and report current values i can see the values change when joystick is moved
    set as port 1 and push, but emulators dont see it.
    i set it to port 1 for the mouse and pressed the fire button and it accted like the left mouse on an intro but thats as much luck as i have had.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »19.10.12 - 16:55
    caver99
    any idea what settings i need to set as i am stumped
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »19.10.12 - 18:13
