website crashes
    amyren
    Posts: 219 from 2010/5/15
    This webpage does crash OWB 1.17 every time I try to visit it.
    (application is meditating)
    opensat4all.com
    I did try briefly using owb 1.7, and that version didnt crash, but was unbearable slow on that page, and with cpu load at 100% almost all the time.
    The page loads quickly with firefox on the pc, so any idea what is wrong?
  • »13.09.12 - 15:23
    Posts: 1090 from 2004/9/23
    Works fine here. Just a few seconds to load all data and done.
    Geit
  • »13.09.12 - 16:01
    Posts: 12543 from 2003/5/22
    > (application is meditating) opensat4all.com [...] any idea what is wrong?
    Works fine here. If you have the swfdec plugin activated, does disabling it make a difference?
  • »13.09.12 - 17:25
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It works fine with Flash as well here. However, if you use Flash plugin with OWB 1.17 from MorphOS 3.1 ISO it will crash (some issue when using cairo.library).
    So if you need to use Flash, download OWB 1.17 from my website (or from Grunch) and then Flash will work (as well as swfdec can work, that is ;)).
  • »13.09.12 - 21:27
    Posts: 2730 from 2003/2/24
    @Fab
    There seems to be some error in versioning when you have to resolve to references like "1.17 from MorphOS 3.1 ISO" vs. "1.17 from my website"!
  • »13.09.12 - 21:37
  • Fab
    Fab
    Well, i'll probably release 1.18 to avoid this confusion.
    Also, the version on the site has SVG support, unlike the ISO version. I often release SVG & non SVG version, so it's not that different as usual actually. ;)
  • »13.09.12 - 23:25
