The Perfect Softsynth. (HD-Rec Plugin)
    XDelusion
    Posts: 602 from 2010/10/27
    The author of HD-Rec has made a post in Amigaworld.net that I think some of you might find to be of particular interest:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=27401&forum=15
    Wanderer:
    "I am currently planing a new softsynth for HD-Rec (or other CAMD oriented apps).
    Because I am in planning phase, everything is still open. I was wondering, what features people really like in synthesizers.
    I will do a graphic to explain my so-far-plan, but here quickly in text form:
    * 4 waveform generators that can be connected by various alogrithms
    * algorithms: FM, AM (multiply), wave shaping (lookup), mix (add)
    * waveform generator can be sample, noise, saw, triangle, square, free-hand
    (wheras interally they are all the same, just looped samples)
    * all generators have a wave sample (or multisample), an LFO and Envelope that are freely assignable to pitch, volume and others.
    * wavesamples can be pitched in harmonic intervalls
    * at the end of the wave generator chain is a filter with various HighPass/BandPass/LowPass/Distorsion implementations, including LFO and Envelope
    * Appregiator (e.g. for C64 blurb sounds)
    The whole thing makes a "layer". An instrument can consist of 1 to 4 layers.
    What do you think? Is this a good and flexible synth, or is something missing?
    Such a synth can do old-school C64 sound, but also mature synth sounds and acoustic instuments via samples."
  • »05.08.12 - 16:03
    Posts: 12538 from 2003/5/22
    ...almost 4 years ago. His plans have changed slightly since then which you can read about in that same thread:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=27401&forum=15&start=20#675431
  • »05.08.12 - 17:51
    XDelusion
    Hmm, guess I didn't pay attention to the post dates.
  • »05.08.12 - 18:07
