Manipulators in Blender on MorphOS 3.1
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    I have strange problem with Blender 2.46 and 2.62 for MorphOS. I can't move and rotate objects using manipulators (three arrows and three circles). I can't catch the manipulators using mouse. Scale manipulators work well. I am sure that it was working well on MorphOS 2.7. Unfortunately on MorphOS 3.1 I have that strange problem (I don't know how it works on MorphOS 3.0).
    What is the reason of the problem? Does someone have the problem? Could I fix it?
    I use Pegasos II G4/1000 with Radeon9200 and MorphOS 3.1.
  • »26.07.12 - 21:41
  • MDW
    MDW
    I got message from other Blender/MorphOS user. The problem exists on MorphOS 3.0 too.
  • »27.07.12 - 04:17
    kiero
    Posts: 129 from 2003/2/28
    most likely something got broken during reimplementation. i will have time to investigate this issue in about two weeks so maybe we can find some workaround for blender.
  • »27.07.12 - 07:16
    Yomgui
    Posts: 348 from 2004/8/31
    After 3 months in Quebec I've just received most of my furnitures, computers and so on, yesterday
    \o/
    Let me rebuild everything... I can give a try this week end to see if it's MorphOS or Blender related.
    And now... next project!
  • »27.07.12 - 19:30
    Posts: 919 from 2004/1/24
    Bit OT, but seems GLHexen has problems with the new 3D system as well. Some walls and floors (well, quite a few really) become transparent. Makes it easy to find hidden stuff though ;)
    [ Edited by Stevo 27.07.2012 - 23:45 ]
  • »27.07.12 - 20:44
  • MDW
    MDW
    kiero, Yomgui
    Thank you for help. I am waiting for results of the research. I hope that effort of the fix won't be very big. :)
  • »27.07.12 - 22:13
