BlueHD issue
    xyphoid
    Posts: 870 from 2008/7/11
    Not sure if thid is an issue since 3.0 update, but I get an application is meditating
    message when trying to use bluehd. I get as far as selecting whe to put temp then any action
    after that results in the message.
    Snoop resulted in this
    [1] [« Requester Slave »] [Open] [muidebug] [Read] [Fail]
    [2] [BlueHD] [Open] [IXPPCSTACK] [Read] [Fail]
    [3] [BlueHD] [ToolType] [WINDOW] [] [Fail]
    [4] [netinfo.device] [Open] [ENV:sys/net/group] [Read] [Fail]
    [5] [netinfo.device] [Open] [ENV:sys/net/group] [Read] [Fail]
    [6] [BlueHD] [Open] [muidebug] [Read] [Fail]
    [7] [MUI-Asl-Popup-Task] [Open] [muidebug] [Read] [Fail]
    [8] [MUI-Asl-Popup-Task] [Open] [muidebug] [Read] [Fail]
    [9] [BlueHD] [Open] [muidebug] [Read] [Fail]
    Any ideas?
  • »26.07.12 - 02:43
    Posts: 3336 from 2003/3/5
    A *debug* log would be handy here. SnoopDos output is useless.
  • »26.07.12 - 10:19
    xyphoid
    I can't be bothered! Burned it on the mac side after 3 coasters! with liquiddvd.
    Neither stock drive nor usb drive worked, on morphos( which used to work without issues)
    I've made a few dvds on morphos. Frying pan failed creating the coasters,
    and jalapeno didn't initiate burn either after creating the temps.
    BTW ffmpeg ver2010 is 'now' unstable. it takes a few tries to convert the avi to mpg,
    without stalling or locking up the system
  • »26.07.12 - 15:21
    Posts: 12572 from 2003/5/22
    > ffmpeg ver2010
    Do you have a link? I could only find a 2009 version.
  • »26.07.12 - 18:17
    xyphoid
    I'm really not sure Andreas, I clicked info in c, and it came up as modified 07-feb-10-time
    I saw the nov 09 ver on fab's page, but it also has a different MD5:
    nevermind it appears both are the same (MD5) on fabs page
    mine has 10548 blocks for whatever reason
    [ Edited by xyphoid 26.07.2012 - 16:22 ]
  • »26.07.12 - 19:08
    Alright, so you have the same 2009 version apparently. Just to be sure, here is the output of the version I have:
    "FFmpeg version SVN-r20529, Copyright (c) 2000-2009 Fabrice Bellard, et al. built on Nov 15 2009 00:16:01 with gcc 4.2.4 (Fedora 4.2.4-6)"
  • »26.07.12 - 19:47
    xyphoid
    output - FFmpeg version SVN-r20529, Copyright (c) 2000-2009 Fabrice Bellard, et al.
    yep, they are the same..
  • »26.07.12 - 20:57
