simplemail and gmail
    sonter
    Posts: 12 from 2012/6/24
    anyone have sucess using a gmail account with simplemail ? mine wont connect to the server. is there any other mail clients I could use that does work ?
  • »23.07.12 - 13:46
    Miky060
    Posts: 694 from 2003/2/24
    Have you already tried YAM?
  • »23.07.12 - 14:02
    Posts: 2217 from 2003/2/24
    I'm using (and been using for a long time) SimpleMail with gmail and it works fine.
    First, do you have amissl v1 installed? SimpleMail needs it for secure connections, which at least I am using with gmail.
    My config for receive settings is:
    POP3, pop.gmail.com, port 995, whole email address for login. Active, avoid duplicates and secure selected.
    And for sending:
    smtp.gmail.com, port 587, login&pw. Use SMTP AUTH, secure and log into pop3 server first selected.
  • »23.07.12 - 14:15
    Crumb
    Posts: 737 from 2003/2/24
    Simplemail works fine. But I had to do weird stuff installing AmiSSL. I remember I installed v3, then v1, v2, v3... and then it worked
  • »24.07.12 - 06:47
