Emule
    4pLaY
    Posts: 80 from 2003/2/17
    Someone on IRC showed me a link to a page with a Emule client for MOS with GUI =) you can see a screenshot i took here http://home.no.net/forplay/EmuleMOS.png or get it youreself NOW from http://www.rusback.org/ (webpage is in french).
    http://www.resistance.no
  • »11.01.04 - 16:27
    warface
    Posts: 653 from 2003/2/24
    I get error 36 when connecting, then soon after it freezes. Any idea what am I doing wrong?
  • »11.01.04 - 17:16
    4pLaY
    Sorry havent had more time to try it out! just dont forget you need to get server.met file.
  • »11.01.04 - 17:42
    Posts: 65 from 2003/2/10
    I don't know who spread this news, but Bourriquet is not yet usable,
    you can only connect to a server, search for file, but you can't
    download... it is far too early to talk about this software which
    should be promising anyway.
    N'cha, LorD
    http://www.lordfpx.com/
  • »11.01.04 - 17:52
    4pLaY
    My friend said he got it from the news at AW! i have no idea if its true as i dont use that page and never will.
  • »11.01.04 - 18:18
    warface
    Without that I couldn't even try to connect, so I have server.met files :-) It just crashes when trying to connect to a server.
  • »11.01.04 - 18:26
    zeXar
    Posts: 30 from 2003/7/22
    Yes, I posted Bourriquet link for amiga/mos at IRC channel #morphos. The new is from AW.NET :-/
    Pegasos II G3/600MHz
    AMIGA 4000 060/50Mhz 604e/233MHz
  • »11.01.04 - 19:53
