WARP 3D DRIVERS UPGRADE NOW (2005)
    serge
    Posts: 725 from 2003/2/20
    Ohhhhhhhh !
    I'm so excited.
    Radeon 3D drivers working like a charme her !
    Alibox is back, Quake 2 flys .
    This is a very very good news !
    Thank you very much MOS team.
    Added year to avoid confusion
    [ Edited by hooligan 16.07.2012 - 14:22 ]
  • »27.08.05 - 10:39
    Posts: 2732 from 2003/2/24
    I so agree! :-D
  • »27.08.05 - 10:43
    tokai
    Posts: 1289 from 2003/2/25
    please note its not Warp3D drivers. ;) The package includes Warp3D wrapper (which wrap old Warp3D apps to the new 3D stuff), but not Warp3D drivers itself. ;)
    regards,
    tokai
  • »27.08.05 - 11:41
    Toto
    Posts: 268 from 2003/4/20
    This is great! Thanks MOS team...
    Games tested and working;
    GLQuake
    Wipeout 2097 (yes I can play it again on my Peg  :-) )
    Heretic II demo (on Shogo CD)
    *Alybox
    *d3Gnop
    *SopoBlock
    *Yamgp (needs lucyplay.library)
    Shogo
    Freespace
    Quake2
    *error when starting but they work.
    Tested but not working atm;
    GLMatrix (worked on my voodoo3, not sure though, long time ago)
    edit: updated tested games list
    [ Edited by Toto on 2005/8/27 20:27 ]
  • »27.08.05 - 11:54
    pegasosuser
    Posts: 138 from 2004/4/9
    @Toto
    wich graphics card have You?
    SHOGO works now fine with this update.
    I have the RADEON9250-256Mb
    I sal testing HereticII and other Games.
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »27.08.05 - 12:36
    Toto
    @pegasosuser
    I have got a Radeon 9200/128MB. Mayby I should reinstall Shogo or copy it from my A4k.
  • »27.08.05 - 12:40
    Toto
    Ok Shogo works now. I did not use capital letters when I typed the serial code. Gone reinstall Freespace now, mayby the same issue.
    Freespace works now, same mistake  :-o
    [ Edited by Toto on 2005/8/27 17:14 ]
  • »27.08.05 - 12:49
    x56h34
    Posts: 29 from 2004/11/1
    Payback seems to work, but a little glitchy.
    Peg 2 G4 / Radeon 7000 64MB here.
    I'll try out Quake 2 and Freespace soon. ;-)
  • »27.08.05 - 17:10
    serge
    I would like to test foobillard from sixk web site, but dont have agl.library.
    Does somebody know this lib?
  • »27.08.05 - 17:21
    zukow
    Posts: 662 from 2005/2/9
    agl is from warpmesa package, wait for native mos ports.
    there were on sdl.innoidea.hu year ago but this site is now closed
  • »27.08.05 - 18:26
    Jupp3
    Posts: 1193 from 2003/2/24
    Toto,
    Are you using the Hyperion version?
    If so, why? At least for me, it feels rather buggy. It crashes a LOT from simplest things (such as shooting an asteroid), unless I disable some important features, such as ingame music.
    Anyway, back to the point. There's a MorphOS native version of Freespace 2, which can run Freespace 1 data files. And as it uses more modern engine, the graphics look a lot better.
    Anyway, here's the link to MorphOS native versions of both. Released back in 2006 :-)
    -EDIT-
    Should have checked the year, as this apparently predates at least the 2006 update of Freespace. But in any case anyone still uses the Hyperion version, it might be a good idea to upgrade to a version with engine based on Freespace 2 :-)
    [ Edited by Jupp3 16.07.2012 - 12:38 ]
  • »16.07.12 - 08:36
