using key morpher
    serge
    Posts: 725 from 2003/2/20
    I'm searching to afect the Write Amiga key fonction to the Right
    control key because I bought a mini keyboard without write Windows
    key.
    I tryed with Key Morpher, but I dont understand how it works.
    Need some help.
  • »03.02.05 - 19:37
    Posts: 98 from 2004/6/4
    key.
    Need some help.
    I'll tell you a secret  :-o ! Nobody know how it works.  8-) Even it's author.  :-D
    WBR, Vladimir Berezenko
  • »04.02.05 - 04:55
    vovka
    Posts: 24 from 2004/5/9
    hey! i know how it works! 8-)
    but mapping qualifier keys (like Shift, Alt, Control, Amiga) impossible using keymap. that's why KeyMorpher can't help.
    AmigaOS has no keyboard driver...  :-(
  • »04.02.05 - 05:07
    Wishmaster
    Posts: 342 from 2003/6/29
    This would be possible with a special Input Handler.
    If it's really needed I could create one.
    [ Edited by Wishmaster on 2005/2/4 11:21 ]
    Pegasos PPC
  • »04.02.05 - 08:20
    BatteMan
    Posts: 294 from 2003/2/24
    Wishmaster : I'm interrested too ;-)
  • »04.02.05 - 08:40
    Robin
    Posts: 741 from 2003/2/24
    If your keyboard is usb you can use
    Poseidon-Prefs to use a different key as qualifier.
    I've had the same prob :-) Now I use the menu-key
    as right-amiga
  • »04.02.05 - 09:39
    BatteMan
    Robin : I did it before my installation of Linux. Now, I need a keyboard in the OF and my USB-PS/2 keyboard is not supported yet in USB with the 1.2 OF... So, I plug it on the PS/2 port but I can't remap the Amiga right... sic.
  • »04.02.05 - 11:15
    Wishmaster
    Try if this is working for ps/2 keyboards:
    KeyFix
    Pegasos PPC
  • »04.02.05 - 11:41
    Minuous
    Posts: 166 from 2010/2/12
    as right-amiga
    Do you mean the USB module of Preferences? I can't find any way to change key bindings there. Or did you mean somewhere else?
    Can I just use SetKey etc. like on a classic Amiga?
    [ Edited by Minuous 25.06.2012 - 23:44 ]
  • »18.06.12 - 23:40
    Minuous
    I still have the same problem...I assume there must not be a solution for it in this case.
  • »07.07.12 - 13:48
    Korni
    Posts: 473 from 2006/2/23
    http://tokai.binaryriot.org/public/remap-1.0.lha - remaps Menu key as RCommand.
    To test it just start from CLI.
    To install and use it daily add following line to user-startup:
    Run <>NIL: Remap <>NIL:
    For general key remapping there is MMkeyboard or Poseidon preferences.
  • »07.07.12 - 14:28
