IGNITION installer script fails! looking for C; copyfiles?
    osco
    Posts: 680 from 2009/10/20
    Has any installed IGNITION on Morphos :-D  :-D
  • »30.06.12 - 12:31
    Posts: 1362 from 2004/2/8
    I did. You need to fall back to old 68k installer, otherwise you'll get an error. The program seems to work OK.
  • »30.06.12 - 18:48
