No more possible to use amifish
    Brumiga
    Posts: 270 from 2004/4/3
    Hello,
    It is no more to me to use amifish to translate little words. I obtain the following error message : 'Erreur Amarquee : TCP Connection Closed'. So that amifish needs amarquee.library to work the error comes from there. But why from day to next day amifish, via amarquee.library, can it not connect itself to babelfish ?
    I have tried with an old morphos 2.7configuration, before adopting the pack ultimate of papiosaur, and the result is identical.
    Brumiga
  • »05.06.12 - 12:19
    defender
    Posts: 249 from 2011/4/24
    I have installed the programm and it said tcp connection closed.
    That seems to be a fault in http://www.babelfish.com/ because it
    responses to slow. It took OWB 10 sec and more to open the page.
    So maybe the problem is solved tomorrow.
    defender
  • »05.06.12 - 12:53
