Pegasos 2 How2
    Hawk
    Posts: 204 from 2003/12/29
    If someone is interested, I wrote a report on assembling the Pegasos II and installing some software. I will be updating it when I manage to complete the different tasks remaining ;-)
    http://nakajima-www.cs.titech.ac.jp/~david/hhhalbum/pegasos/
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »07.01.04 - 08:43
    Hawk
    BTW, I installed jabberwocky 1.4, but i can not read incoming messages. Chat window is ok. I think it's because MUI TextEditor.mcc is not working properly. I downloaded it from Aminet. But when I select TextEditor in MUI Prefs I don't get any prefs windows...
    any help?
    EFIKA
  • »07.01.04 - 10:32
    MaSC
    Posts: 63 from 2003/12/1
    Great guide,:) should be usefull when I can use my PegII (ie when easyetrader.com get off thier buts and send me that memory and case I ordered on the 23rd dec).
    You may need the MUI mailtext.mcc to read incomming messeges. Search on yah local Aminet:)
  • »07.01.04 - 10:42
    Hawk
    yeah! you were right :-)
    now it works!
    I can add it to my list now ;-)
    EFIKA
  • »07.01.04 - 10:59
    Posts: 157 from 2003/3/3
    Hawk: having SnoopDos (Amiga version from Aminet works ok on MorphOS) helps a lot. Witht that program you'll be able to see if some additional libraries (or in this case, mui parts) are needed for the program.
    http://somequicknotes.blogspot.com/index.html
  • »07.01.04 - 11:07
    Hawk
    Oh! I forgot about SnoopDos! :-D too many years without using Amiga... anyway, I think for new users, with no amiga experience, a lot of things may be kindda enigmatic... More basic info would be nice... Well, I'm still updating my guide. I'll write about SnoopDos today ;-)
    EFIKA
  • »08.01.04 - 03:27
    liquidbit
    Posts: 408 from 2003/10/12
    nice review Hawk... about the booting thing ...pegasos boots also with the commando: boot cd boot.img
    I will try to see if are other boot possibilities like via USB or Network card.
  • »08.01.04 - 13:16
