OWB 1.16 hanging?
    osco
    Posts: 680 from 2009/10/20
    Running Mos 2.4 and recently the browser is hanging loading a page ...right at the end of recieving. also a system message that " the application seems to be dead" ??
    Running 1.11 and all is normal?
    Tried to reinstall 1.16 but no luck? :-?
  • »23.05.12 - 08:12
    Posts: 2727 from 2003/2/24
    osco,
    Running Mos 2.4
    Just out of curiosity, why MorphOS 2.4 and not 2.7? It's a free upgrade, and much happened in 2.5, 2.6 and 2.7...
  • »23.05.12 - 08:38
    osco
    :-) i was waiting for 3.0  :-D
  • »23.05.12 - 09:59
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    In particular, it requires charsets.library from 2.7, else it will just die during some charsets conversion. So just install 2.7?
  • »23.05.12 - 11:39
    Fab,
    ...and perhaps someone should update this? :-P ;-)
    Requirements
    MorphOS 2.x is strongly advised, but it can still work on a 1.4.x setup with a
    recent enough MUI snapshot (2007).
  • »23.05.12 - 12:24
  • Fab
    Fab
    It still works on 1.4.x though, but on 2.x, it really requires the latest charsets.library, because its functable was changed.
  • »23.05.12 - 16:01
