How to copy a CD/DVD with FryingPan or MakeCD ?
    defender
    Posts: 249 from 2011/4/24
    I have tried to copy a CD with FryingPan but I've ended up with a few crashed CD's.
    FryingPan has no direct copy Button, so if tested MakeCD it was able to make an image
    of a CD but it can't burn with my Pioneer DVD writer. The image file is not loadable with
    FryingPan.
    After trying for an hour I've started debian and copied the CD in less then 10 minutes.
    I can't believe that there is no way to do this with MorphOS.
    What am I doing wrong ?
    Thanks for your help!
  • »07.04.12 - 18:42
    CountRaven
    Posts: 566 from 2007/12/10
    Yeah there is a good CD/DVD software solution missing from the Amiga world :( those MakeCD and FryingPan programs sees a bit out fated.
  • »08.04.12 - 03:55
    MarK
    Posts: 641 from 2004/1/25
    well, first create a CD image, and then burn it as many times as You need it :) i made this several times in past with both MakeCD and FryingPan.
    bye, MarK.
  • »08.04.12 - 05:59
    Posts: 1390 from 2010/1/6
    There is no need for a "copy"-button....
    1:1 copy (FryingPan): Make image_file from CD, switch from "Create new disc" to "Import existing disk image", drag&drop image there (or put it to "session file"-requester) and burn it - that's all!
    Other way without iso image: Copy content of CD to HD, drag&drop all files to FryingPan and burn it .......
    (With 2 cd-drives you can copy "on the fly" - works fine on my PEG2 with internal burner and 2nd USB-Drive.....)
  • »08.04.12 - 10:03
    defender
    MarK,
    Amigaharry2,
    OK, I see what you want me to do. Honestly its what I tried to do ... again and again. By now I've got a big bag of plastic trash. And
    no working CD.
    But maybe you can help me with this. How do you create a CD-image with FryingPan that can be burned afterwards (and does show the same contents)?
    I found 2 ways to make useless images.
    For example :
    1)Go to the contents page select the session and press download tracks.
    2)Go to the tracks/ISO Builder press Add and select all content, then press Build image.
    Now maybe someone can tell me how to do it right ?
    I use FryingPan 1.3.2 downloaded with a link from amiga.org.
    MakeCD does not work with my CD writer.
    Thanks for your replies!
    greets defender
  • »08.04.12 - 15:53
    boot_wb
    Posts: 874 from 2007/4/9
    defender,
    FryingPan.
    Have you tried manually selecting the correct driver for the DVD drive in MakeCD's preferences? This is probably CDR_SCSI3_ATAPI.driver as per MakeCD's support pages.
    To accomplish this I'd use MakeCD. Select the CD as the source and image file as destination (as you have done) with makecd. Then choose the image file as the source and a blank CD as the destination.
    MakeCD is actually a really powerful burning program even through the GUI, it's just not very clearly laid out imho: too many different windows popping up.
    It even gives you the option of automatically deleting the image file from hdd once it has been burned, essentially giving a CD>CD copy mode.
    Just a thought, but you aren't trying to make a DVD (rather than CD) image file (ie >2GB) on a 2GB limited filesystem such are you? This would obviously cause problems.
    Also, ensure you aren't burning the disk image as a file onto the destination CD (easy mistake if you aren't familiar with a particular burning utility).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »08.04.12 - 17:54
    defender
    MakeCD did something that looked really strange to me.
    It made 24 files as a Disk image but somehow it made a useable
    music cd with 12 tracks like the original.
    Hey I just needed 7 hours to (nearly) understand the program -
    I need to play with it some more :-)
    FryingPan is still refusing, but maybe I get to it some how.
    greets
    defender
  • »08.04.12 - 19:27
    Posts: 12558 from 2003/5/22
    I guess you didn't bother much with the excellent documentation then ;-)
  • »10.04.12 - 07:03
    defender
    I trashed most of my CD's with the 'help' of FryingPan (just because it came with PackUltimate).
    Tried the online documention - that does not really help. I had never used MakeCD and it looked to
    me like it could not write to my CD writer. It refused to write the first 3 attemps I made.
    In the last 6-8 years there was Nero and K3b and for these programs you do not need to read
    (not even think about what you are doing). I bought a 50cd-r pack because I am eager to
    get one of my favorit games to run on my CD32 (Globdule from Psygnosis). I have an ISO
    that works with uae but not with the real thing. Now I take a look into MakeCD's docs to see
    how far it will get me :-)
    greets defender
  • »10.04.12 - 12:56
    realstar
    Posts: 298 from 2003/2/24
    Despite it's dated appearance MakeCD is actually an excellent CD burning software. You will end up with less coasters for sure if you stick with MakeCD. I have never had very good luck with FryingPan although it has become at least somewhat usuable now. Still MakeCD is a program you can trust. :)
  • »10.04.12 - 13:13
    Cannot agree! Im doing all my Cds and DVDs with FP without any troubles. I can't understand defenders problem: FP is very easy to use (all drag&drop like copying a HD) and (my opinion) self-explainable.... (a brief documentation of the older FP (V0.4) can be found on FPs homepage - it may be helpfull)....
  • »10.04.12 - 16:13
    All the more important is consulting the documentation.
    > Now I take a look into MakeCD's docs to see how far it will get me :-)
    Wise decision eventually. I think I will never understand why so many people keep ignoring the documentation, jumping through all kinds of hoops and only use the docs as a very last resort, if at all. That's very much like meaning to fail. I mean there're people who have put much effort into writing these things ;-)
  • »10.04.12 - 16:57
    hooligan
    Posts: 1948 from 2003/2/23
    Well, you know.. for copying disc one shouldn't even need to to read documentation :)
  • »10.04.12 - 17:50
    True. The ideal application is completely self-explanatory. And the less ideal the handling of an application is, the more important a good documentation and also reading that documentation get. MakeCD needs some getting used to, maybe also due to the Triton GUI, but its documentation is really good in my opinion.
  • »10.04.12 - 18:14
    Jambalah
    Posts: 820 from 2008/3/30
    Walking thru dvd authoring I supposed that creation of a dvd with menu was the most difficult part.... I was wrong!
    Burning a dvd it's becoming a nightmare  :-D
    Before I surrender to any windows burning cd/dvd prog and since FryingPan is not useful (useless, I mean) to burn an iso image, is there somethimg to do?!?
    I tried with dvdrtools but I have poor results (read: burned 7 dvds with no results and errors...). Anyone use it?!?
    I'm using a LG DVD burner (wich works ok for cd burning) but no lucky with dvd.
    Tia for any help!!!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »22.05.12 - 18:05
    xyphoid
    Posts: 870 from 2008/7/11
    Two ways in doing this, depending on what you're trying to accomplish.
    1st, probably easier, use bluehd program but you need to install a buch of programs, and make sure arguments are right do a MZ search for threads.
    It will convert to mpeg then you burn the ts_files to dvd which will give you a playable dvd on "some" players (not magnovox).
    or
    2nd, convert video file to mpeg format using eg.
    ffmpeg -i file:mymorphos:yourfile.avi -s hd1080(if you want this format) -target dvd file:yourdrivewithroom:temp/file/yourfilename.mpg
    which ever converter works for you, some prefer mencoder...I don't.
    Install dvdauthor and create an auth.xml file and go from there. This is usually quicker, but as fickle, if not more.
    eg
    <dvdauthor dest="yourdrivewithroom:temp/DVD">
    <vmgm/>
    <titleset>
    <titles>
    <video format="ntsc" aspect="16:9" />
    <pgc>
    <vob file="yourdrivewithfilelocation:" chapters="0,300,600,900,1200,1500,1800,2100,2400,2700,3000,3300,3600,3900,4200,4500,4800,5100,5400,5700,6000,6300,6600,6900,7200,7500,7800,8100,8400,8700,9000," />
    </pgc>
    </titles>
    </titleset>
    </dvdauthor>
    copying and pasting this above to editor(rename auth.xml), sustituting your arguements, then open a cli (shell window) and do
    dvdauthor -x mymorphos(your.xml file location):auth.xml
    should get you the necessary formats then drag and drop into fryingpan (registered)
    Again a raw playable dvd is created without buttons or chapters.
    Chapters are doable, but I haven't mastered buttons as it requires positioning ect, and I'm not that pressed for them.
  • »23.05.12 - 01:46
    Jambalah
    Thx Xyphoid!
    I've never used bluehd program (I will try) but I tried dvdengine unsuccesfully.
    So I studied some tutorials in the web to make a complete dvd authoring using different programs.
    I used:
    mp2enc to create a mp2 file (to use with dvd menu, required)
    jpeg2yuv to create a n frames video starting from a jpeg image and I piped datas to mpeg2enc to create a m2v video
    mplex to encode mp2 file with m2v file so to have a menu with sound
    spumux to create the menu adding buttons (a single button in my case) to previous mpg file (the menu video file)
    dvdauthor to create the dvd structure joining together menu and effective video-film
    mkisofs to create an ISO image to burn on a DVD
    The DVD structure seems to be correct though I noticed some problems trying to play dvd with MPlayer (using "play dvd from directory" option):
    if I use no dvd menu video is heavily slow (cache fill, play 1 or 2 seconds, stop and restart).
    If I use dvd menu:
    - menu background image has some graphic corrupted parts (jpeg2yuv encoding problems? I will check this..). Graphic issues are not visible if I play menu vob file.
    - pressing "play movie" buttons makes the video-film start but button doesn't disappear! FForward solve but it shouldn't happen....
    - video has no audio though is there... Playing the vob file causes no problems at all and audio is fine.
    Let's go studying some more! =D
    The real problem now is to burn a DVD!! I wasn't able to perform this with FryingPan (registered) and I don't know if this is a DVD burner problem. I suspect LG burner is not appreciated by FryingPan wich sometimes recognize a new (recordable) dvd disc as a "read-only" disc. Not mentioning FryingPan doesn't recognize ISO images too... That's why I tried DVDRtools a suite wich has inside "dvdrecord" command to burn CDs/DVDs but again no luck.
    I'm going to try this on MDD DVD burner (Pioneer) and let's see what is going to happen...
    Pegasos II 1 ghz
  • »23.05.12 - 12:02
