Amigamark 1.1 failing on MDD MOS 2.7?
    redrumloa
    Posts: 1424 from 2003/4/13
    I'm running benchmarks between a Quicksilver and a MDD in another thread and I cannot get Amigamark to work on the MDD. It will work on the Quicksilver, but the application will not run at all on the MDD. Double clicking does nothing. If I try to execute from shell I get "Failed to create application!"
    I'm a bit baffled. If I am missing something stupid, be gentle.
  • »02.05.12 - 22:53
    Posts: 1521 from 2003/2/24
    What Snoopium says when you try to run it?
  • »03.05.12 - 02:15
    Posts: 611 from 2003/4/11
    There has been some updated AmigaMark version fixing this problem AFAIK.
    Check out the author's HP at http://www.219.dic.at/ for latest files.
  • »03.05.12 - 13:23
    Posts: 12558 from 2003/5/22
    The thread title says "1.1", so I guess this is what redrumloa runs.
  • »03.05.12 - 17:18
